Hello Guest it is November 07, 2026, 06:36:02 PM
Author Topic: Initialization Macro Called on Reset?????  (Read 10869 times)
« on: January 21, 2011, 06:02:04 AM »
I just performed a new install of Mach3 and every time I try to run it I get this as a result. It will run until it hits any M code and the stop. Can anyone tell me as to what it is that I am doing wrong?
 I'm only using Mach3 on this Vista System to check my code before sending it to my Windows XP system which controlls my mini-mill.
Re: Initialization Macro Called on Reset?????
« Reply #1 on: October 04, 2012, 08:26:20 PM »
I know this post is 120 days old but, did you ever get this problem solved
I would like to know because I got the same problem after installed XML file
into the Mach 3 loader....everything looks with a machine profile in loader
but, I am unable to reset the software.....
