Hello Guest it is November 28, 2026, 02:16:40 PM
Author Topic: Mach 3 Spindle rpm inaccurate  (Read 41923 times)
Re: Mach 3 Spindle rpm inaccurate
« Reply #20 on: January 15, 2011, 07:55:02 PM »
The output of the sensor is going strait to the printer port, no bob, no traces to anything on the
controller board, just a open pin #15 on the rs232 strait through cable, and yes I tested the cable
just in case ( I have been dumb before and grabbed a bad cable  ??? by accident. )
In the pulley configure I did make sure the ratio was 1:1 as the sensor directly reads the spindle.
slot size, on a 2" disk ,I would think that .2" wide would have been more than enough.
I can try another disk if you think it would help. I once saw the calculations some where
but making a new disk will only take a few minutes.
« Reply #21 on: January 16, 2011, 01:45:35 AM »
I dont know if it would make a difference, if its easy enough to do then you might as well try I suppose.
Just wondering if you can disable the PWM in Mach, call a M3 and spin the spindle by some other means, maybe even by hand to see if the relay switching is the problem.
