Hello Guest it is November 01, 2026, 10:13:33 AM
Author Topic: Pimp my Lcam  (Read 46596 times)
Re: Pimp my Lcam
« Reply #20 on: November 28, 2006, 06:31:41 PM »
Downloaded 2.17 update today and although the version of LCAM still says 3.12 I can see that it has been updated as well. THANK YOU VERY VERY VERY VERY much for the change on the viewing (or lack thereof) on disabled layers.  Can I consider it an early X-mas present?  You guys are the best!
Sid
Re: Pimp my Lcam
« Reply #21 on: November 28, 2006, 11:03:10 PM »
Sid that is all I am getting you this year  ;D
www.newfangledsolutions.com
www.machsupport.com
Offline PaulWC
  •  125 125
Re: Pimp my Lcam
« Reply #22 on: November 30, 2006, 09:22:56 AM »
Hi Brian,
Noticed a couple of things...
With a simple part having four layers: four hole drill pattern, single hole drill, inside pocket and outside contour. The second layer drill hole behaves as though it is still tied to layer one when selected in the part view. When selected in the LayerTree Properties, it is not selected in the part view.
Also, when entering values in Layer/Object Properties, such as 5/16" (0.3125), it will only accept three place decimal values (0.312 with keystroke beep when trying to key the 5) even though it shows four place decimal values.
And for Benny... just found out the Attach function does not allow the new file type "*.LCam".
Paul, Central OR
Re: Pimp my Lcam
« Reply #23 on: December 01, 2006, 08:39:21 AM »
The decimal point code is fixed and we are looking into the drill point problem.
thanks
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Pimp my Lcam
« Reply #24 on: December 01, 2006, 02:35:18 PM »
Hi, Brian
Any idea when new LC ver. will be out fixing the AutoClean and Optimise features with multi layer DXF ?
Have you had time to look at my DXF file below, post it and see the errors that I was talking about ?
Thanks, Chip
Offline PaulWC
  •  125 125
Re: Pimp my Lcam
« Reply #25 on: December 01, 2006, 06:00:00 PM »
Hi Brian,
Thanks for the continuing work...
Art mentioned a Shft-Ctrl left click for us two button mouse people for part rotation. I don't have it with LC in ver .017. Is it slated for the next greatest release?
Thanks again, Paul, Central OR
Offline Chip
  •  2,055 2,055
Re: Pimp my Lcam
« Reply #26 on: December 01, 2006, 11:17:53 PM »
Hi, Brian
Just an up-date, New LC 2.00.0.20, Didn't fix any of the issues I sent you, o-well.
Thanks, Chip
Offline PaulWC
  •  125 125
Re: Pimp my Lcam
« Reply #27 on: December 02, 2006, 01:11:16 AM »
Hi Brian,
I just tried the .020 ver and the drill point/layer thing works for me now.
I still can't enter "-0.3125"... key beep on fourth decimal place.
Also, still no way to rotate part (3D view) with two button mouse?
And, I apparently lost the control for showing chain direction arrows (triangles).
Paul, Central OR
