Hello Guest it is October 21, 2026, 09:15:28 AM
Author Topic: reset all defaults  (Read 8263 times)
reset all defaults
« on: January 10, 2011, 12:09:34 PM »
I don't know what happened everything was working just fine then all of the sudden I started getting all kinds of strange D,R,O read outs. Everything works fine until I send a file to mach from Vcarve then i get all kinds of crazy readings. I have uninstalled a reinstalled both mach3 and Vcarve. I am still getting same results. Before I just wipe out and reinstall everything on my computer. I would like to try to set mach3 to its original defaults. Will someone tell me how to do this.
Thanks in advance.
Chris
PS all of my configurations remain the same
Re: reset all defaults
« Reply #1 on: January 10, 2011, 03:24:07 PM »
It could be your code that is changing the values.
You can however go back to a saved xml, you can use the restore settings  from the Operator menu.
