Hello Guest it is November 13, 2026, 05:18:40 PM
Author Topic: Xbox 360 Plugin Problems  (Read 8270 times)
« on: January 08, 2011, 11:45:46 AM »
Having some problems with the xbox 360 plugin.
I installed all of the software put the file in the plugins folder.
Running xp
pluged in the wired microsoft xbox360 controller
it saw the controller and I got the one green light on the controller.
In Mach3 I went to plugins and could not find an option for xbox 360 listed only joystick.
Enabled it and the controller worked but I can only control x and y with the left thumb pad nothing else works.
What am I missing?
Brian
Re: Xbox 360 Plugin Problems
« Reply #1 on: January 09, 2011, 10:52:42 AM »
I needed to restart the PC a couple of times to get it to show up on the control panel.  Also,  i went the Microsoft website to get the latest DirectX. But I would think that the plugin would not work properly till Mach3 sees it.
I disabled the any plugins that I am not using.  i.e. joystick.
But I have to say that the xbox controller is a VERY nice set up.  I noticed that some of the buttons are analog so the further you press the faster the movement.
« Reply #2 on: January 09, 2011, 07:41:12 PM »
Ok tried all of those things and no luck any other ideas
