Hello Guest it is November 13, 2026, 05:54:29 PM
Author Topic: Pokeys driven Mach CNC Keys........  (Read 14133 times)
« on: January 07, 2011, 06:41:34 PM »
Here is what the Mach CNC Keys powered by the PoKeys do.
Primary board M31A   (first board)
secondary board M31B (second board)
secondary board M31C (third board)
M31A functions:
cycle start, single step, load program, set next line
feed hold, reverse run, Close program, run from here
stop, M1, rewind program, block delete
reset, edit, recent program, ref all
M31B functions:
Spindle CW, Speed Inc+, Feed Inc+, Jog On/Off
Spindle Stop, Speed Reset, Feed Reset, Jog speed +
Spindle CCW, Speed Inc-, Feed Inc-, Jog speed -
GoTo Zero's, Teach, Stop Teach, Shuttle Mode
M31C functions:
Select X for MPG jog, Select Y for MPG jog, Select Z for MPG jog, set step jog to 0.001
Select A for MPG jog, Select B for MPG jog, Select C for MPG jog, set step jog to 0.01
Enable Positive Jog 50% rate, Fast jog rate 100%, Enable Negative Jog 50%, set step jog to 0.1
Continous Jog, Incremental Jog, MPG Jog, set step jog to 1
