Hello Guest it is November 19, 2026, 07:35:19 AM
Author Topic: STATUS: Radius to end of arc differs from radius to start on Line number #  (Read 10760 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Hi, All
If your using LasyCam and getting, STATUS: Radius to end of arc differs from radius to start on Line number # when running Mach3.
It generally happen's after running program in INC Mode, then loading Gcode with G02, G03 in it..
You need's to change your Post Pre and Post Amble's, as it is now it generate's a Pre G90 G80 G40, Post G40 G80 M30 in one line.
Mach3 doesn't read and process multi-Gcode command's on one line. may at some point.
Edit it to look like this.
Pre.
G90
G80
G40
Post.
G40
G80
G90 ( I added this may not be needed though)
M30
It's been driving me crazy.
Hope this Helps Chip
« Last Edit: November 13, 2006, 02:46:44 PM by afn09556 »
