Hello Guest it is November 25, 2026, 06:12:34 AM
Author Topic: Referencing and Home Offset  (Read 11587 times)
Offline Scott
  •  140 140
« on: November 13, 2006, 11:05:48 AM »
Is it possible to have Mach automatically move the X, Y, and Z to the actual X and Y location of my table after it's done referencing without adding some extra code to the "Ref All Home" button?  I have the offsets set in the "Homing and Limits" screen, but that just changes the DRO's.
Scott (Another new guy on the Mach ;-)
Scott
Re: Referencing and Home Offset
« Reply #1 on: November 13, 2006, 11:28:37 AM »
Sorry you will have to add code to the button :( It is not as bad as you think :)
Add this to the button and you will have it
Whlie IsMoving()
Wend
Code "G53 Xx.*********x Yy.yyyyy"
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: November 13, 2006, 12:15:24 PM »
Hi, Scott
You can also use Active Tool Offset's
Not an expert hear, Go to Offset's page, click on Fixture 2 G55, enter your table offset's ( value you want is the location you want to start cutting on table).
Now return to Program Run Screen Regen tool path, you should see your item to cut is offset by the amount set in Fixture 2 G55.
In the DRO's you'll see a -X, -Y value, that's shows current position of where your located from fixture offset, if you click on Machine Coord's you'll see ABS X 0, Y 0 which is your Home Ref. point.
Now you can Run your Gcode should be fine.
Changing back to Fixture 1 G54, Regen tool Path will return your Cut and View Ref. to Home location
Just scratched the surface of offset's, many other ways to do this like, editing your Gcode, insert a G55 just before your first cut, save changes, ref Mach3 manual in Tutorials above .
Dry Run this to confirm propper operation.
Don't Forget to save the Fixture offset's on exit of Mach3.
Hope this Helps ,Chip
Offline Scott
  •  140 140
« Reply #3 on: November 13, 2006, 12:24:06 PM »
Thanks guys,
Couldn't I also edit the script for the ref button with a G28 If I have things set right for "Home Offset" and in the G28 home location coordinates?
Scott
