Hello Guest it is October 21, 2026, 03:02:13 AM
Author Topic: jog hot keys  (Read 10431 times)
jog hot keys
« on: January 01, 2011, 07:13:46 AM »
Hi everyone can someone explain how to reset jog hotkeys back to 999 spent hours trying but no joy
Re: jog hot keys
« Reply #1 on: January 01, 2011, 10:52:34 AM »
Only way I know is to edit the xml manually, if you open in notepad then Ctrl and F then in the search box type AxisKeys0 that will find the entry for X++ if you want x-- then its AxisKeys1, Y++ its AxisKeys2  etc etc.
The other way to do it is to click on the hotkey to open the keystroke entry box and then just pres the red cross, that should enter zero in there which I think will basically be ok as well.
Re: jog hot keys
« Reply #2 on: January 01, 2011, 01:28:24 PM »
Many thanks will give it a go
