Hello Guest it is November 23, 2026, 04:39:26 AM
Author Topic: Mach3 not saving configuration  (Read 25430 times)
Offline fiamma
  •  11 11
  • It's just a thin Blue Line
« on: December 30, 2010, 09:16:16 AM »
Hi again Folks and Happy New year.
I finally had everything where i wanted it, and went to the top and saved setting ( but it does not save ) I keep finding this out due to the Lovely Microsoft way it freezes up the computer, Not Responding, etc to the point where i need to reboot. ( Unlike my Mac , HINT HINT ! )
Even though it was saved, all settings are lost.
Any advice?
Thx ???
Re: Mach3 not saving configuration
« Reply #1 on: December 30, 2010, 09:53:53 AM »
I dont think Mach fully saves the config until you actually shut Mach down.
Offline fiamma
  •  11 11
« Reply #2 on: December 30, 2010, 12:35:53 PM »
hi again ! actually it turns out that the file was set to read only.
But now I have another issue! I wrote to Tom at Candcnc and I guess I was to use the Bladerunner version of Mach3 or my system wont work.
Problem is, I copied all ports and pins and homing limits. But can not get the machine to move anymore. I am beside myself, I almost had it all set. can you check and see this xml if you can see a problem? I hope this is the file.
Thx
Rob
« Reply #3 on: December 30, 2010, 01:33:45 PM »
Do you have a copy of the xml you had almost running?
Offline fiamma
  •  11 11
« Reply #4 on: December 30, 2010, 01:56:13 PM »
no, thats the problem, It overwrote it :-(
« Reply #5 on: December 30, 2010, 02:17:24 PM »
Not so good :( No real way of me knowing if the correct pins are set :(
Offline fiamma
  •  11 11
« Reply #6 on: December 30, 2010, 03:28:02 PM »
Ok, after playing with it, i finally got it to move again, but the motors move REAL s l o w :-)
« Reply #7 on: December 30, 2010, 03:35:57 PM »
Likely you need to set the steps per unit up to suit your  motors/drives and maybe the accel and Vel settings as well.
Offline fiamma
  •  11 11
« Reply #8 on: December 30, 2010, 03:38:16 PM »
Thanks for all your help Hood,  !
Happy new year !
« Reply #9 on: December 30, 2010, 03:41:20 PM »
No probs and you too.
