Hello Guest it is October 20, 2026, 03:09:01 PM
Author Topic: Soft limits and slaved axis  (Read 11452 times)
« on: December 29, 2010, 01:33:18 PM »
I tried engaging soft limits today on a machine with a slaved axis and got the error "Machine out of limits for A axis".  A is slaved to Y.  The A axis DRO always reads zero and under homing/limits, A min is set to -100 and A max is set to +100.  Seeing as how the DRO reads 0 and that is inside the set range, I'm thinking it should work.
Does anyone know what could be going on?
Re: Soft limits and slaved axis
« Reply #1 on: December 29, 2010, 01:41:58 PM »
Couple of things that might be the possible cause, first is have a look at the A's machine coords if you have not already done so. Other thing is rotational softlimits are off on General Config.
Offline Repmo
  •  54 54
« Reply #2 on: January 05, 2011, 06:50:53 AM »
i had similar problem with my softlimit on my fresh lathe retrofit,
my soft limits works very good, it stop good on both axis but when i try to run program, mach3 send messagebox warning if my program run within 4 inch of the soft limit ....
if i escape the alarm, the program run good without close position with limit
i have only .75inch of slowzone in soft/home screen, this lathe run on diameter mode, i use smoothstepper
tanks
fred
« Reply #3 on: January 05, 2011, 08:34:26 AM »
I'm still not sure what's going on.  I tried Hoods suggestions but still getting the same error when I try to activate soft limits.  One thing I figured out is that the error message does not specify the A axis.  It just says that "Machine is out of limits for soft limit activation", so the problem could be on any axis.  Once I get some time to mess with it, I'll dig a little deeper.
« Reply #4 on: January 05, 2011, 08:45:37 AM »
If you want to attach your xml I will see if I can figure out whats going on.
Ok back to the welding, need warmed up ;D
