Hello Guest it is November 12, 2026, 05:36:33 AM
Author Topic: Position or torque mode?  (Read 47521 times)
Offline smurph
  •  1,575 1,575
Re: Position or torque mode?
« Reply #20 on: January 04, 2011, 09:45:02 PM »
From your debug file:
SH ABCA
MO ABCA
Or more precisely, you have Mach axis X mapped to Galil axis A AND you have Max axis A mapped to Galil A.  That is what is trowing the commas off.
Steve
« Reply #21 on: January 05, 2011, 06:41:40 AM »
Thank you for catching that.  I did have that setting wrong.  A is now mapped to D.  I looked at my older galildegbug.txt file from position mode, and it was set correct then.
This was the old plugin that I was trying.  Still no luck with the new one, it would not recognize the motion card.
Thanks!
Rob
« Reply #22 on: January 05, 2011, 07:05:39 AM »
I just tried running the machine under mach again, and results are strange.
The Y and Z move as told, although not quite as smooth as from galil smart tools.
The X axis sounds like a jackhammer when mach tries to move it.  I think this is because mach plugin is telling the galil to GA,,,A rather than GA,,,CX.  not quite sure yet, will try again after work.
Cheers!
Rob
