Hello Guest it is November 12, 2026, 06:10:34 AM
Author Topic: Problem in Motor Tuning  (Read 10779 times)
Offline Shivu
  •  18 18
« on: December 29, 2010, 01:09:19 AM »
Hi all,
I am trying to change the value of step per in the motor tuning, when i changed the value of step per to any value the Graph disappears and the velocity will become ZERO. and i am not able to enter the velocity the velocity will become ZERO even if  enter the new velocity value.
Any solutions?
Shivu.
Offline smurph
  •  1,575 1,575
Re: Problem in Motor Tuning
« Reply #1 on: December 29, 2010, 07:25:10 PM »
I'm not sure on this one.  Some parameter is not right.  You might post this question to the General section and get more responses.
Steve
« Reply #2 on: December 29, 2010, 09:13:54 PM »
Just in case you ran into the same problem as I did... Go to Config > Ports & Pins > Motor Outputs. Make sure the axes you want to run are enabled with the check mark. Last week I was unable to use the Motor Tuning menu in mach and the graph was not working right either... It was because I had not enabled the axes in the Motor Outputs tab.
Josh G.
