Hello Guest it is November 12, 2026, 06:24:45 AM
Author Topic: Homing Problem  (Read 9979 times)
Offline Shivu
  •  18 18
Homing Problem
« on: December 28, 2010, 01:11:50 AM »
HI All,
I am using MACH3 software for a turning application with Galil DMC 2133, i could operate the machine fine in all aspects. but i am facing problem in homing.
When i give home command from Galil by using Galil command homing is working fine, but when i give command from the MACH3 the Home limit has no effect the motor continues to jog even after Home limit till it reach the end Limit.
Do any one have solution for this.
Shivu
Re: Homing Problem
« Reply #1 on: December 29, 2010, 09:10:41 PM »
Shivu,
I don't have a solution to your problem. I am having the same problem! I am curious: what are your settings in the galil plugin? Specifically, under Axis Setup / Motor Type? (Servo motor, servo reverse?)
Also, what are your settings under Homing?
I look forward to your reply. Maybe we can help each other figure this out.
Josh
