Hello Guest it is November 22, 2026, 02:28:46 PM
Author Topic: Milling parts from end of stock  (Read 42767 times)
Re: Milling parts from end of stock
« Reply #30 on: January 01, 2011, 04:31:29 PM »
HHS for that app I would use 500 rpm and feedrate of 10 IMP doc .050" then set FRO to 50% adjust from there. Lots of coolant if a avaliable. Monitor chip load and chip color.  Even cuting with 1/4" bit not a problem IF your cut paramaters are correct.
