Hello
Guest
it is
November 12, 2026, 07:13:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
Pin Numbers for the AUX connector on 2040
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pin Numbers for the AUX connector on 2040 (Read 11061 times)
Muskymistry
3
on:
December 27, 2010, 04:53:26 PM »
HI
need help
trying to setup an MPG using the Aux X axis.
I have told Galili plugin - MPG#1 axis = X(A) and checked box for Use Aux, Encdr
in Mach the setting for MPG are = MPG#1 is enabled, A-Port is 1 , A-Pin is
, B-Port is 1 and B-pin is
Logged
kcrouch
193
In way too deep!!!
Re: Pin Numbers for the AUX connector on 2040
Reply #1 on:
December 27, 2010, 06:42:48 PM »
The plugin doesn't need the pins enabled in Mach only that the MPG is correctly connected to the Galil. You'll need to go to the tabout screen in Mach and enable jogging and MPG mpde and setup an increment such as .005" and select the axis to move. Use Smartterm to make sure that the encoder is hooked up properly.
Cheers,
Kenny
Logged
Having way too much fun! Something must surely be wrong.
Muskymistry
3
Reply #2 on:
December 27, 2010, 06:58:33 PM »
thanks
next question
where in mach do i map the inputs and outputs for the extended I/O on the galil 2040.
I am actually converting from a Grex over to Galil on a bridgeport interact mill
on the Grex I had 26 inputs and 12 output LED's on the panel..
thanks
Logged
kcrouch
193
In way too deep!!!
Reply #3 on:
December 27, 2010, 07:01:23 PM »
The mapping of extended i/o is explained in the PDF file on the Mach plugins Galil web page.
Kenny
Logged
Print
Pages:
1
Go Up
« previous
next »
