Hello Guest it is November 23, 2026, 07:07:04 PM
Author Topic: SmoothStepper and THC  (Read 11317 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
« on: December 24, 2010, 08:48:48 AM »
As I can see on forums, SmoothStepper doesn't support THC function on Parallel port 2.
Is there any solution if someone want smooth stepping without parallel ports?
Many new mainboards haven't good results on Drivertest.exe, I think because of the SMI function.
Mrpeja
Re: SmoothStepper and THC
« Reply #1 on: December 24, 2010, 01:28:21 PM »
You can always use a self contained THC that does its OWN z controlling. Mach thens runsGcode as a 2 axis machine.
Offline mrpeja
  •  114 114
« Reply #2 on: December 25, 2010, 04:05:20 AM »
Hi BR,
I'd like to use old THC300. Maybe I can use SS for steppers and other things, and have another Parallel port for THC function as usual?
Mrpeja
« Reply #3 on: December 25, 2010, 09:53:46 AM »
Talk to your THC manf most should offer there stuff as a stand alone controller that runs the Z axis motors independantly from MACH . It just needs 2 outputs to tell mach ArcGood and ArcLost so mach knows when to move and stop.
Talk to TOM at CandCNC he is very well versed in THC design and operations
