Hello Guest it is November 21, 2026, 03:19:24 PM
Author Topic: Voltage Output on M3  (Read 28647 times)
« on: December 23, 2010, 08:14:46 AM »
Hi all.
I seem to be having trouble with the 7535 break out board on my interpreter 1000.
For some reason I am getting an output voltage on M3 even when all outputs are disabled, including port 1, pin 1, which should control that specific output.
All the other outputs change properly.
I have updated the firmware and the mach 3 plugins.
Any help would be much appreciated.
Thank you
Re: Voltage Output on M3
« Reply #1 on: January 06, 2011, 02:08:38 PM »
As for now that is how the the system works, as soon as you set a spindle speed in mach3 the motion controller will put out the commanded analog voltage.
This is something I want to change in the future but it works fine for VFD's so I haven't pushed to get it changed!  Just a side note there isn't any acceleration or deceleration on the analog.  It is always on according to the set spindle speed.
Andrew
Andrew
MachMotion
