Hello Guest it is November 13, 2026, 05:19:58 PM
Author Topic: PoKeys v. 10.6.3 is released.........  (Read 11001 times)
« on: December 22, 2010, 11:55:16 AM »
update 10.6.3 22Dec10
1). Fixed a bug in the Matrix Keys function.
2). REVISED the PoKeys.set, screen set, the Digital IO, ULEDs start at 2001-2055
to match the PK pins 1-55 better. This changed made me move up by one, the Analog
stick control for jogging leds from 2055, and 2056, to: 2056 and 2057 respectively.
The OEM numbers on the Analog Joystick plugin config userLEDs are OEM'ed at those
numbers as well.
3). NOTE!!!!  PoLabs really did some nice work on how they are handling MPGs, the
current MPG functions are so fast, that you DONT have to use the "Use Fast Encoders"
from the PK SW, or from the plugin dialog, leave it unchecked, so it doesnt use up
some of your other IO points. In real world testing, I can't really see a difference,
between "Regular speed" and "Fast Encoders" at this point. I guess if your turning the
MPG with super duper fast rates, then it might be useful to you.
Sent to Boris, and should be on his website for download very shortly.
scott
Offline borisz
  •  220 220
    • www.poscope.com
Re: PoKeys v. 10.6.3 is released.........
« Reply #1 on: December 22, 2010, 12:58:40 PM »
It is avaiable on www.poscope.com
regards
Boris
