Hello Guest it is September 21, 2026, 06:26:54 AM
Author Topic: New Leadscrew, need settings  (Read 13869 times)
« on: December 22, 2010, 08:05:42 AM »
Hi
Would anyone know what settings i need to enter to drive a new leadscrew.
The leadscrew i have purchased is http://www.worldofcnc.com/products.asp?recnumber=61 its the 12x3D.
Im about to test the x axis on a new machine im building.
Anthony.
Re: New Leadscrew, need settings
« Reply #1 on: December 22, 2010, 09:22:41 AM »
Need more info such as what microstepping are your drives and do you have reduction between motor and screw.
« Reply #2 on: December 22, 2010, 09:34:05 AM »
Hi Hood
Just a  look on the side of the motor,
dont think this will help but here you go
57BYGH013-09BE
1.8o  1.8A
NO:20100707
These motors came off a chinese mini CNC that i bought a few months back, so getting microstepping info might be a problem. There is no reduction between the motor and screw, the motor has a 8mm shaft so i turned the leadscrew down to 8mm.
thanks
« Reply #3 on: December 22, 2010, 09:47:27 AM »
Ok so without knowing the microstepping it will just be a guessing game. If its chinese leadshie drives it uses it will likely have the info printed on the top of which dip switches do what so you might see what its set to.
If not then use the  Set Steps utility on the Diagnostics, or could be settings page and that should get you as close as your measuring. Once thats done then you will be able to work out really what the microstepping is as it will be a round number, so say for example the set steps work it out at 540 you can divide that by 66.66666666666666 and it would come out with a value of 8.1 so you would know its set at 8 uS so then you can calculate it by 200 steps fr motor x 8 uS then divide by the 3mm pitch.
« Reply #4 on: December 22, 2010, 09:49:08 AM »
Currently mach is set up to work with the chinese CNC,
Settings for the motors are as follows
Steps Per: 800
Velcocity: 1500
Acceleration:200
Step Pulse:5
Dir Pulse:3
Not sure if that info would help or not.
« Reply #5 on: January 02, 2011, 02:56:51 PM »
Sorted this now thankyou.
I used to Set steps util, sorry for wasting your time, i did not know Mach had that.
Thanks.
« Reply #6 on: January 02, 2011, 04:22:55 PM »
Great news :)
