Hello Guest it is November 23, 2026, 01:09:38 AM
Author Topic: Need a quick answer/Please  (Read 15907 times)
« on: January 22, 2006, 10:14:03 AM »
Could a spst momentary push button switch the type commonly available at Radio Shack be used as a limit/homing switch?
ynneb
Re: Need a quick answer/Please
« Reply #1 on: January 22, 2006, 04:43:28 PM »
Yes, But I do not know if it should be normally open or closed, you will need to find this out.
It would be best suited as a limit switch and not a homing switch. Homing switches need to be very accurate in terms of setting zero to the same point every time. I think microswitches are better for accurate homing.
