Hello Guest it is November 12, 2026, 07:40:58 AM
Author Topic: Control Synrad Laser with Galil DMC-1842 via Mach3 ?  (Read 11103 times)
« on: December 21, 2010, 07:22:50 AM »
I am working with a machine that has the Galil DMC-1842. I understand that will work with mach. This machine however, has a synrad J48-2S laser on it driven by their UC-2000 laser controller. I want to set it up to do not only vector engraving, but raster engraving as well. Is that do-able? Anything I should be forewarned about?
Re: Control Synrad Laser with Galil DMC-1842 via Mach3 ?
« Reply #1 on: December 22, 2010, 04:46:31 PM »
I'm going to reply to my own post here. I have found out that it is not possible to use the impact/laser engraving plugin with Galil in Mach3. Art Fenerty informed me that Mach only supports that functionality when using the parallel port. Hope this helps someone else!
Josh Glenn
http://www.cncexperts.com
