Hello
Guest
it is
September 30, 2026, 02:07:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Plasma tube cutting
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Plasma tube cutting (Read 85087 times)
Overloaded
4,923
Re: Plasma tube cutting
Reply #10 on:
December 24, 2010, 06:29:08 AM »
Logged
geast
51
Reply #11 on:
December 24, 2010, 06:39:53 AM »
Does SwapAxis() operate on maxCL mode?
Logged
Carnoustie, Scotland
Reply #12 on:
December 24, 2010, 07:05:13 AM »
Quote from: geast1967 on December 24, 2010, 06:39:53 AM
Dont know but likely it wont, give it a try and see though as thats the only way to know for sure. If it works please let us know.
Logged
geast
51
Reply #13 on:
December 24, 2010, 07:24:46 AM »
I just make a button with code SwapAxis(0,3) but it didnt make anything.
I also check the configuration for a change at the pins and port screen, for motor output but nothing changed also.
Do i have to restart every time i hit the button ?
Logged
Reply #14 on:
December 24, 2010, 07:38:43 AM »
Looks like it doesnt work with MaxCL then.
You wouldnt see any changes in Ports and Pins, just the axis would swap.In other words if you commanded an X Axis move the motor on the A would actually move and vice versa.
Logged
geast
51
Reply #15 on:
December 24, 2010, 08:23:00 AM »
So the only way to do it is by electrical swap the pins with a relay.
Logged
stirling
2,188
UK
Reply #16 on:
December 24, 2010, 08:23:45 AM »
Haven't really read all the thread properly so forgive me if I'm out of line. swapAxis is a bit quirky and there's a couple of things to bear in mind when using it.
You can only call it once. That is you must then call resetAxisSwap before calling it again.
When you call swapAxis you'll see the change in step/dir in ports n pins.
motor settings do not follow the swap. Just the step/dir pins.
I have no idea what maxCL mode is but I just ticked it and tried a swapAxis and it worked for me V3.042.040.
Ian
Logged
Razordance Torch Height Control
Reply #17 on:
December 24, 2010, 08:37:08 AM »
Stand corrected there, never noticed that earlier but of course I was using the wrong version of SS plugin when simulating so obviously never saw the pins swap
Regards MaxCL mode I am not sure you could look at ports and pins as I think they are basically ignored and Mach internally sets the ports and pins to the specific ones the MaxCL machines require.
Logged
stirling
2,188
UK
Reply #18 on:
December 24, 2010, 08:56:27 AM »
yep - just read up a little on maxcl and as you say it appears to use pin assignments of it's own and ignores whatever is set in ports n pins. Tried to confirm this with parmon and it looks correct. So although swapaxis still works it's not having the desired effect. sorry for the sidetrack.
Ian
Logged
geast
51
Reply #19 on:
December 28, 2010, 04:01:08 PM »
For BR549
How can sheetcam make the conversion to the A axis as you mentioned?
Can you give me an example?
Thank you in advance.
Logged
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
