Hello Guest it is September 06, 2026, 07:12:15 AM
Author Topic: problem size in mach3  (Read 35278 times)
« on: December 17, 2010, 04:04:15 PM »
hi, can anyone explane please after i put gcode into mach3 itis always reads  wrong size ex if i want square 1in it engraving it gos to  0.940 so i have to  creat square 1.325 in till i get 1 square inch i need your advise please
T1M6
G0Z1.0000
G0X0.0000Y0.0000S15000M3
G0X0.0121Y0.0202Z1.0000
G1Z0.0000F9.4
G1X1.3371Y0.0202F14.2
Y1.3452
X0.0121
Y0.0202
G0Z1.0000
G0X0.0000Y0.0000
G0Z1.0000
G0X0Y0
M30
« Last Edit: December 17, 2010, 04:07:35 PM by kocher »
Re: problem size in mach3
« Reply #1 on: December 17, 2010, 04:19:24 PM »
If you command a 1 inch move via the MDI line does it actually move 1 inch?
« Reply #2 on: December 17, 2010, 04:25:17 PM »
no if i command a 1 in  it will be  0.740 . thank hood  for your help.
 T1M6
G0Z1.0000
G0X0.0163Y0.0198Z1.0000
G1Z-0.0250F9.4
G1X1.0163Y0.0198F14.2
Y1.0198
X0.0163
Y0.0198
G1Z-0.0500F9.4
Y1.0198
X0.0163
Y0.0198
G1Z-0.0750F9.4
Y1.0198
X0.0163
Y0.0198
G1Z-0.1000F9.4
Y1.0198
X0.0163
Y0.0198
G0Z1.0000
G0X0.0000Y0.0000
G0Z1.0000
G0X0Y0
M30
« Last Edit: December 17, 2010, 04:27:19 PM by kocher »
« Reply #3 on: December 17, 2010, 04:29:26 PM »
Then it sounds like you have your steps per unit set wrong.
If you tell me the following info I will work out what your steps per unit should be
Is it steppers?
What microstepping do your drives have? (or make/model if you are not sure)
Do you have any reduction between motor and screw?
What is the TPI or pitch of the screw?
« Reply #4 on: December 17, 2010, 04:35:22 PM »
 the steppers are direct drive. (helical couplers )
  high-precision linear Round rails, diameter 0.8-inch,
  The use of high-precision new ball screw,
there is no rebound in return;  diameter 16 mm; pitch 10 mm;
  Aluminum alloy T-slot table,  Can help you cut and fixed,
  Manufacture than wood table has a huge advantage,
   NEMA23 stepper motor current is 3A, the weight 2.2 pounds ,Torque 1.7n.m 245 oz.In.
    30v 3A CNC drive,tb6560 , Optical isolation, the maximum 1 / 16 micro-step,Spindle control relay
     400w 30v Switching Power Supply
 spindle motor is  850w, 4 level speed, 5000--30000RPM, Strong power;
  milling tool diameter:  8mm,6mm,3.175mm
Router is the length of 28 inches, width
 thanks  for your  answer
« Reply #5 on: December 17, 2010, 04:37:55 PM »
Do you know the microstepping you have the drives set to, it says there that Max is 1/16, is that what you have it set at?
Are your native units inch?
« Reply #6 on: December 17, 2010, 04:44:12 PM »
sorry all i know u did help me to run my machine in past i have this info it may help again thanks for your advise . steps per 760 .velocity 151.98. Acceleration 4. step pulse0 dir pulse 0 .
« Reply #7 on: December 17, 2010, 04:52:20 PM »
Ok can you attach your xml and I may be able to work it out from there. With the steps per unit at 760 it would mean from the above info that you are just 1.49 microstepping which doesnt sound right.
« Reply #8 on: December 17, 2010, 04:54:22 PM »
Ok looking at your numbers I am thinking you are at 1/2 stepping so your steps per unit would be 1016, give that a try and see.
« Reply #9 on: December 17, 2010, 05:07:17 PM »
i did put 1016 per step its working  perfect size  thank very much it is  working 100% thank you .
