Hello Guest it is November 10, 2026, 01:55:18 AM
Author Topic: Wizard Shapes  (Read 6596 times)
Wizard Shapes
« on: December 17, 2010, 08:59:56 AM »
I tried to use the “Wizard Shapes Program” to cut a D shaped hole through 1/8” plastic. But it refused to generate the G code by saying; the offsets can’t be > then tool diameter. This makes no sense because I had it set on contour which just plunging through and I had all the offsets set at zero. I know this program works because I had used it before to cut a hex. What am I doing wrong?
Fred
