Hello Guest it is November 28, 2026, 06:59:02 AM
Author Topic: Internal taper wizard  (Read 14079 times)
oziie34231
« on: November 09, 2006, 05:43:48 PM »
In a world where all of us  have zero backlash machines this wizard would be fine, but a few of us do not.
The cuts should be made from the inside out, so that the x feed is feeding into the metal, at least that should be the case with shallow number angles. The pressures on the Z axis are minimal.
What think Brian?
Jerry
Re: Internal taper wizard
« Reply #1 on: November 10, 2006, 05:26:58 PM »
That is a good idea but I think that is going to have to be put off for the Lathe CAM and we hope to do... Art and I have lathes that we would like to make code for!
www.newfangledsolutions.com
www.machsupport.com
oziie34231
« Reply #2 on: November 11, 2006, 08:31:06 AM »
Cool. When you get to it.
By the way that same problem exists with many of the wizards, i.e. they do not take into account that many machines have backlash (some might say all machines) and cut in such a way that the tool can easily be pushed away from the workpiece.
Jerry
