Hello Guest it is November 28, 2026, 06:49:09 AM
Author Topic: turning an ellipse wizard needed  (Read 20559 times)
Offline zarzul
  •  233 233
  • Wyoming, USA
« on: November 09, 2006, 10:11:55 AM »
Anyone got an idea on how to make a wizard for turning an ellipse?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: turning an ellipse wizard needed
« Reply #1 on: November 09, 2006, 01:05:11 PM »
Let me guess,
Your chess bishop is the problem!
Are you talking about a fixed ratio curve or an involute curve,  if its fixed ratio you can do it with 2 # variables and a sub routine.
If you want some code give me some sizes length/dia ratio and I will post an example.
Graham.
« Reply #2 on: November 09, 2006, 01:05:41 PM »
O boy that is not as simple as it sounds :(
I think that Cam is going to be the only way to get that ...
www.newfangledsolutions.com
www.machsupport.com
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #3 on: November 09, 2006, 01:49:25 PM »
I was afraid it would be complex, I just don't have enough trig knowledge to know where to even begin.   I really didn't have any dimensions in mind yet.  The different things I would like to make (of course you guessed it the bishop) along with a host of other uses,
airplane prop spinners, candlesticks that kind of stuff.   If you have some ideas on the basics, tell me more about the fixed ratio curve.  I will search the internet for something to read on it.
I am looking at fairly small diameters 2" to 1" , and fairly short lengths 2" and less.
Arn
  •  2,785 2,785
« Reply #4 on: November 10, 2006, 03:19:44 AM »
OK, give me a few days and I will dig out the routines, convert them from Fanuc macro code and post them in a Mach format for you.
Graham.
« Reply #5 on: November 13, 2006, 01:26:15 PM »
An ellipse is what you see when you slice through a cone at an angle. If you need equations try the wikipedia link.
http://en.wikipedia.org/wiki/Ellipse
It has everyhing you would ever want to know about an ellipse
Thanks.
Bill
Pixel Tamer
