Hello Guest it is October 14, 2026, 03:16:24 PM
Author Topic: Keling C35 BOB  (Read 8357 times)
Keling C35 BOB
« on: December 13, 2010, 06:50:13 PM »
I'm not sure if this is the right place for this question, but has anyone used the Keling C35 BOB with the Gecko G201 or G203 drives?  I see that they bill it as "quick connect" which is only really true is you use their drives.  Does the little RJ45 -> pin-out board they supply match up to the Gecko drives?  If not, I see a couple of options.  (1) Make an RJ45 -> pin-out that does work or (2) Just strip back the drive end of an RJ45 cable.  What have you done and how did it work out?
Any other comments about this BOB...Good or bad?
Re: Keling C35 BOB
« Reply #1 on: December 14, 2010, 06:59:04 AM »
Dear Sir,
There are several connector boards for the RJ45 connectors used on the C35 and C32 boards.  Are you using one of these?
http://www.cnc4pc.com/Store/osc/index.php?cPath=33_59
If you want, you can also cut an RJ45 cable and wire it yourself.
Arturo Duncan
http://cnc4pc.com
