Hello Guest it is October 20, 2026, 07:48:34 PM
Author Topic: machine running irregular on button script  (Read 65771 times)
« on: December 13, 2010, 02:49:30 PM »
Hi All,
I am encountering a problem when running a button script.
It is a fairly simple probing script, for measuring flatness of a surface.
There are a few dro's involved for surface size, grid size, etc.
The script uses some Do Until...Loops to scan a surface for flatness in a regular grid.
Scanned XYZ values are written to a textfile.
For instance, on a surface of 270 x 400 mm with a 20mm measuring grid about 300 points are beeing probed.
This takes about 10 minutes.
During this scan my machine sometimes acts strange, it looses steps and is running irregular.
Also, when the probe hits the surface "G4 P.25" is used, a pause to allow for writing values to the textfile.
About 1 in every 100 times the pause is skipped, the probe backs off immediately to go to the next piont.
XYZ Values are written okay though..
Is there some explanation for this strange behaviour?
I never loose steps when running g-code.
I can run complex programs without a problem.
So, is there a way to scan with a g-code file?
Can XYZ values  be written to a textfile while using g-code?
I mean g-code in a .NC-file, not g-gode in a button script.
Thanks for helping!
Rich
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: machine running irregular on button script
« Reply #1 on: December 13, 2010, 03:22:09 PM »
You can run a g-code G31 loop using a sub and some # variables then jump into a custom macro to write the data to a file, that way the moves are all native g-code.
Graham
« Reply #2 on: December 13, 2010, 05:50:04 PM »
Hi Graham,
I have no idea how to do what you say.
I will have to find out how to use # variables...
Are there enough variables available to store 300 to 500 xyz values?   (thus 1500 values)
Some searching and reading will help, I guess... ???
Is it normal that g-code in a button scrip is executed like described, with irregularities?
Does this happen because the VB-script is interrupted by windows, or something like that?
Thanks for helping!
Rich
« Reply #3 on: December 13, 2010, 06:09:58 PM »
I would write each coordinate to an array, then when the process finishes, write the array to the file.  Updating an array is much faster than writing to file.  Just write the file once.
FWIW...I've seen the same issue with G4 pause commands being skipped and it wasn't from a button script.  It is while running a g-code program.  It's usually the first one in the program.  No idea what causes it, but it hasn't been enough of an issue to spend a whole lot of time on.
« Reply #4 on: December 13, 2010, 07:05:12 PM »
Missing the pause isn't the real problem...
It just also happens on an irregular basis.
The real problem is missing the steps...
When I scan say 300 points on a surface, in my opinion the machine should make a repeated regluar sound... probe and step to the next piont.....probe and step to the next point....probe and step to the next point....etc...
But the sound is not regular, like it hessitates sometimes...or sometimes it seems to react faster, skip a pause..
As said, the machine normally never looses steps when running a .NC-file.
Loosing steps while probing from a vb (button) script only occurs on the y-axis.
The y-axis is driven on both sides. It has dual motors, master and slave setup.
My guess for now is that, because of the irregularity, master-y and slave-y are not receiving their commands simultaneous.
Thus tension builds up in the y-axis and steps are lost... ( I hear a "bang" when loosing steps...)
.NC-files, even with repeated operations, never give me this problem... :-\
Thanks again.
« Last Edit: December 13, 2010, 07:10:45 PM by zone023 »
« Reply #5 on: December 13, 2010, 07:19:46 PM »
I thought it might help posting the script... :D
Code: [Select]
Option Explicit
Dim POX As Single  '-- probe offset X
Dim POY As Single
Dim TD As Single  '--Tip Diameter
Dim shiftZ As Single
Dim Xwp As Single '-- X work at probe position
Dim Ywp As Single '-- Y work at probe position
Dim Zwp As Single
Dim minX As Single
Dim minY As Single
Dim maxX As Single
Dim maxY As Single
Dim sizeX As Single
Dim sizeY As Single
Dim stepX As Single
Dim stepY As Single
Dim borderX As Single
Dim borderY As Single
Dim ProbeFeed As Single
Dim RapidFeedXY As Single
Dim RapidFeedZ As Single
Dim Datum As String
POX = GetUserDRO(1501)
POY = GetUserDRO(1502)
TD = GetUserDRO(1503)
RapidFeedXY=GetUserDRO(1615)
RapidFeedZ=GetUserDRO(1615)
ProbeFeed = GetUserDRO(1505)
Xwp = GetOemDRO(800) + POX
Ywp = GetOemDRO(801) + POY
sizeX = GetUserDRO(1601)
sizeY = GetUserDRO(1602)
stepX = GetUserDRO(1605)
stepY = GetUserDRO(1606)
borderX = GetUserDRO(1610)
borderY = GetUserDRO(1611)
minX = borderX
minY = borderY
maxX = sizeX - borderX
maxY = sizeY - borderY
Datum = Format(Now, "yyyymmdd")
Datum = Datum & "-" & Format(Time, "hhmm")
If GetOemLed (825)=0 Then
Open "c:\mach3\scan\SCAN-" & Datum & ".txt" For Output As #1 ' Open to write file.
MsgBox ("Probe will move. Make sure work area is clear. Probe-tip must be about 10mm above work!")
Code "G90 G1 X" & minX - POX & " Y" & minY - POY & " F" & RapidFeedXY  'Move to border
Code "G91 G31 Z-15 F" & ProbeFeed
While IsMoving()
Wend
Code "G4 P0.25"
Call SetDro (2, 0 + (0.5 * TD))
Code "G4 P0.5" 'Pause for Dro to update.
Code "G91 G1 Z5 F" & RapidFeedZ  'Probe backs off 5mm
While IsMoving()
Wend
Code "G90"
Code "G4 P0.25"
Code "G91 G31 Z-10 F" & ProbeFeed
While IsMoving()
Wend
Code "G4 P0.25"
shiftZ = GetVar(2002) + (0.5 * TD)
Code "G4 P0.15" 'Pause for Dro to update.
While IsMoving()
Wend
Code "G90"
Code "G4 P0.25"
Zwp = 0
Write #1, Xwp, Ywp, Zwp
If Xwp + stepX < maxX Then
  Code " G91 G1 Y" & stepY & "F" & RapidFeedXY
While IsMoving()
Wend
End If
Do Until Xwp + stepX > maxX
Code "G4 P0.1"
While IsMoving()
Wend
Code "G4 P0.05"
Zwp = GetVar(2002) - shiftZ + (0.5 * TD)
Code "G91 G1 Z5. F" & RapidFeedZ
While IsMoving()
Wend
Do Until Ywp + stepY >= maxY
Code "G4 P0.1"
While IsMoving()
Wend
Code "G4 P0.1"
While IsMoving()
Wend
Code "G4 P0.05"
Write #1, Xwp , Ywp, Zwp
While IsMoving()
Wend
Loop
Code "G4 P0.1"
Code "G90 G1 X" & Xwp + stepX - POX & "Y" & minY - POY & "F" & RapidFeedXY
While IsMoving()
Wend
Else
While IsMoving()
Wend
Code "G90 G1 X" & minX - POX & "Y" & minY - POY & "F" & RapidFeedXY
While IsMoving()
Wend
End If
Loop
Code "G90"
Close #1
MsgBox ("Scan File saved as c:\mach3\scan\SCAN-" & Datum & ".txt")
Else
Code "(Probe is active, check setup and try again)"
Exit Sub
End If
« Last Edit: December 13, 2010, 07:21:36 PM by zone023 »
« Reply #6 on: December 13, 2010, 07:58:27 PM »
THere are several thing working aginst you with your approach.
The VB is not in any way synced with the Gcode side so the VB can endrun your Gcode if time is short(and will). and vise versa.
The G4 does not control the wait for the VB side  Sleep() is what you use to control the wait in VB. AND it will be nessesary to use it to help control the flow and wait for updates.
THe G31 is very reliable  and accurate IF used like Graham stated entirley in Gcode.The G31 "does" have a report modual that saves all your points to a file AND is very reliable. (;-) Then that part is control from inside of MACH.
I have probed many 100,000s of points with G31 and the save point files with no errors > Can't say that for the VB side using the G31. Sooner or later something gets out of sync.
Just a thought, (;-) TP
« Reply #7 on: December 13, 2010, 08:15:13 PM »
Just a note M40 opens the saved points file and G41 closes it when you are all done.
« Reply #8 on: December 13, 2010, 08:31:37 PM »
You may be missing steps because the PC is busy writing to a file after the G4 finishes.  Mach works best when it is the only thing using PC resources.  In other words, the file write may be taking longer than the G4 is allowing.  You could try increasing the G4 dwell, but personally, I wouldn't be trying to write the file on every G31 move.  Store the coordinates in an array, then when the routine finishes, open the file, dump the array to the file and close the file.
« Reply #9 on: December 14, 2010, 05:41:47 AM »
Hi TP and rrc1962,
Thanks for the reply.
I think I am encountering the problems TP describes.
The way the machine acts while running a VB script already gave me the feeling things are not in sync.
As a quick solution I will try writing results to an array while probing and write the array to a text-file when finshed.
But I think probing with .NC g-code will work better after all...
That means I have to learn how to write g-code subs, I guess.
Also writing to variables is new for me... ???
Of course I will do some searching myself, but is anybody willing to share an example??
Thanks again!
Rich
