Hello Guest it is November 22, 2026, 02:27:18 PM
Author Topic: Tapping 4mm  (Read 9067 times)
Offline Kai
  •  60 60
Tapping 4mm
« on: December 13, 2010, 10:22:06 AM »
I need to tap a 4mm thread in a 3.3mm hole I know the Gcode is G63 is there any other commands to go with it like feed and back off as you would with a normal hand tap?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Tapping 4mm
« Reply #1 on: December 13, 2010, 12:12:26 PM »
The normal command for tapping is G84 G98/99 Z(depth of hole) R(start point above hole) F(Feed rate), depending on how you are set up to do this will depend on the code you use :-
If you have a servo spindle them you can control it like an axis and in effect rigid tap the hole with pitch control. If you swap the spindle with axis A you can do:-
O0002(TAP M4 10 DEEP)
G00 Z2.
G92 A0 (ZERO OUT A AXIS)
G01 Z-10. A-6171.428. F200. (12MM MOVEMENT / 0.7 PITCH x 360 DEGREE)
G92 A0
Z2. A6171.428
M99
If you do not have a servo spindle then you will need a tension/compression holder to allow for the over run of the spindle.  With this set up you can use:-
Call the sub from the main program once over the hole.
O0002 (SUB TO TAP M4 HOLE 10 DEEP)
S200 M3
G00 Z2.
G01 Z-10. F140.
M5
G4 P1000
G01 Z2. F280. S400 M4
M5
M99
Graham
« Last Edit: December 13, 2010, 03:12:48 PM by Graham Waterworth »
Offline Kai
  •  60 60
Re: Tapping 4mm
« Reply #2 on: December 13, 2010, 06:03:56 PM »
many thanks for that
