Hello Guest it is November 07, 2026, 02:03:09 AM
Author Topic: Add Existing Panel  (Read 22530 times)
Add Existing Panel
« on: December 12, 2010, 05:20:02 PM »
Lets say I have a screenset that has a bunch of panels in it, then I design a new screenset.  Is there a way I can take one panel from screenset A and add it to screenset B.  The screen I want to move is fairly complex with lots of VB code and lots of buttons.
Re: Add Existing Panel
« Reply #1 on: December 12, 2010, 05:36:07 PM »
You might be able to do it with Screen Tweak.
http://www.machsupport.com/downloads/Mach3Screen.zip
« Reply #2 on: December 13, 2010, 02:04:21 AM »
Hi rrc1962
you can copy and paste the content of pages with MachScreen. Start 2 instances of MachScreen, use the instance marked "read only" open the screen-set file from where you want to copy, select the page to copy, use "Ctrl C", switch to second instance of MachScreen select the page you want to paste in the content, use "Ctrl V".
Klaus
« Last Edit: December 13, 2010, 02:09:37 AM by Klaus1311 »
The brain isn't a soap, it doesn't shrink when used.
« Reply #3 on: December 13, 2010, 02:27:07 AM »
Hi rrc1962
I forgot to mention, to select all items of a page, you can use "Ctrl A".
Klaus
