Hello Guest it is October 22, 2026, 05:34:06 PM
Author Topic: Mach3 under Windows 7  (Read 24364 times)
« on: December 07, 2010, 02:43:58 PM »
Hi tere!
I have a milling machine runnign Mach2 under XP for years. The PC was stolen so I purchased a new one, XP is no lobger available here so I bought Windows 7 starter
I installed Mach3 using the Vista instructions I found on Mach´s site. Everything owrked well, for a while, and then the motors started to loose steps and make strange noises.
It does not happen all the time. If I start Mach3 and do some jogging only, it works. But after I load and execute some g-code the problems start again.
I tried to swicth Mach3 versions, installed aditional LPT boards, change ALL parameters. It improve but the problem allways happen sometime.
Is Mach3 compatible with W7? Do I need a special version? Do I need to buy an XP machine?
Please help!
Thanks in advance
Alex
Re: Mach3 under Windows 7
« Reply #1 on: December 07, 2010, 02:44:37 PM »
One question more: can I run Mach2 under Win7?
Thanks!
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: December 07, 2010, 02:52:07 PM »
Yes, Windows 7 works great with Mach. If you want to use the parallel port then you must use the 32bit version. If you are using a SmoothStepper than you can use either 32bit or 64bit versions.
Happy machining , Jeff Birt
« Reply #3 on: December 07, 2010, 02:53:43 PM »
Thanks a lot!
What can I do? try another PC? another motherboard brand? Is Win7 starter 32 bits?
Thanks again!
« Reply #4 on: December 07, 2010, 02:56:26 PM »
Run the driver test and see what the graph looks like, if its not great then you could maybe try some of the optimisation ste[s detailed on the downloads page. They are not meant for W7 but probably a lot can still be done.
« Reply #5 on: December 07, 2010, 02:59:04 PM »
Driver test shows a half green bar with EXCELENT legend on it. Is it ok?
« Reply #6 on: December 07, 2010, 03:03:15 PM »
Does the line look smooth or are there large spikes every now and then?
« Reply #7 on: December 07, 2010, 03:07:56 PM »
No visible spikes, may be some pauses in the display, very shot. THANKS!
« Reply #8 on: December 07, 2010, 03:10:40 PM »
Should be ok then.
Is there any power saving options, maybe in the BIOS? Try turning them off if there are.
« Reply #9 on: December 07, 2010, 03:26:57 PM »
Should be ok then.
Hood you´re my new GOD. Thanks a lot! Yo saved my day! I tried several options in the bios and now it is working great!
If you ever came to Argentina I will be happy to buy you a steak dinner!
Thanks again
Alex
