Hello Guest it is November 22, 2026, 02:28:51 PM
Author Topic: How do i pause spindle for auto tool change,set soft limits,& 360'rotate 4th axi  (Read 9854 times)
I reloaded my software from to default settings and now:
EZ-Router with Auto Tool Changer
1)my spindle will not power/rpm down before it puts the tool back in the nylon holder.
 where do i find and what do i adjust to pause the spindle so it wont burn up my holders ?
2)What are soft-limits and how do I re set them?
3) when i try to round off square stock, it rotates 0 to 360 travels in y then 360 back to 0, is there a command for a continuous 360 infinite rotation
thanks
1) Ports n pins, Spindle Setup, General Parameters, Spin DOWN
2) They prohibit you from hitting your limit switches or hard stops. Do a quick search and check the manual....plenty info there.
 3) Gen Config, Rotational, Rot 360 Rollover
There is no continous infinite rotation of A axis like you would with a lathe spindle.  You must Set as stated then program a rotation. You can program more than one rotation if set to rollover by stating the number of degreees of rotation needed  say 3600 deg(10 turns). Also it cannot be a seperate move it must be part of a coordinated axis move A/Y/Z  or A/X/Z
Hope that helps, (;-) TP
« Last Edit: December 07, 2010, 11:17:03 AM by BR549 »
thanks
You can set up a separate profile with your rotary axis as a spindle.
