Hello Guest it is October 20, 2026, 06:44:39 PM
Author Topic: cuts start good but end bad  (Read 13889 times)
« on: November 30, 2010, 12:53:59 PM »
Please help! My projects always start out great and within 30 or 40 min into the cut it starts to mess up. running required machine with XP pro and no other software installed.
Re: cuts start good but end bad
« Reply #1 on: November 30, 2010, 01:10:52 PM »
Bit more information needed.
Mill or Lathe or?
Stepper or Servos?
What exactly happens other than it messes up ;) ?
What spec of computer and what version of Mach
« Reply #2 on: November 30, 2010, 02:35:50 PM »
Sorry Hood,
Don't really know much about this machine. The computer I do know that it has XP pro, running 1 or 2gig of ram and the video card meets the spect listed on the site. The machine its self is a 24" X 36" cnc router (guessing more like a mill) running stepper motors. The machine starts cutting really nice at first the about 30 to 40 min into the cut it starts acting like it forgot where it was or repets the same step over. I hope this is enough info. I'm at work and not sitting infront of the machine otherwise I could probably tell you more. Thanks
« Reply #3 on: November 30, 2010, 02:37:53 PM »
oh and running mach3
« Reply #4 on: November 30, 2010, 02:53:01 PM »
Sounds like your steppers may be stalling, try turning down the acceleration by half on the motor tuning page (from Config menu) remembering to click save axis settings each time.
« Reply #5 on: November 30, 2010, 04:15:05 PM »
motor tuning for x and y are both     285     299.98    10    0.0259019    5    5
don't know if this is correct or not
« Reply #6 on: November 30, 2010, 04:18:06 PM »
Nothing is correct, or rather no one can say what is or is not correct, it all depends on the motors, drives, mechanicals that you have and even two identical machines may vary slightly.
With steppers its really trial and error to see what the best setup is.
« Reply #7 on: November 30, 2010, 08:45:21 PM »
OK, so I changed the acceleration to 5 and now I just get the blue screen of death. The Gcode might run for a minute or two but some times will freeze up my computer before it even starts to run.
« Reply #8 on: December 01, 2010, 01:46:42 AM »
Can you try and run the drivertest.exe, that you will find in the main Mach3 folder, and see what that looks like.
