Hello Guest it is November 07, 2026, 02:04:12 AM
Author Topic: number of digits behind . in dro  (Read 21921 times)
« on: November 29, 2010, 05:47:50 AM »
I'm fairly new to mach 3.
I work in mm's and the dro's have an "accuracy" of 4 digits behind the .   ( for example 5.9997 mm)
can I change this to only have 3 digits behind the .  so I get 6.000 mm?
thanks,
Roel
Re: number of digits behind . in dro
« Reply #1 on: November 29, 2010, 06:04:58 AM »
Sure ... Open the screen set with Screen4, double click on the DRO, then change the 4 in the string to 3.
Mach will still work to 12 - 13 decimal places internally.
Russ
