Hello Guest it is November 22, 2026, 06:34:48 PM
Author Topic: Fast Z on 2.5D machine  (Read 30559 times)
« on: November 06, 2006, 01:08:57 AM »
I am using M functions to activate and deactivate an output (output4) in my 2.5D machine. Everything works fine but there is a delay of some milliseconds (>350ms) from the execution of the M function to the next G command and from a G command to a M function.
Sample code:
N0440 X153.8415 Y44.6080 I5.1038 J-3.4409
N0450 X92.5577 Y69.9926 I-39.1988 J-7.9659
N0460 X90.8241 Y61.4619 I3.3986 J-5.1321
N0470 M17<----------------------------------------------------- (machine stops, M function deactivates output after some ms)
N0480 G00 X131.1282 Y101.9559
N0490 M18<----------------------------------------------------- (M function activates signal but the movement starts after a while)
N0500 G01 X104.6245
N0510 X123.8448 Y121.1526
N0520 X127.6986 Y126.9220
N0530 X129.6661 Y130.8300
M17 code:
DeActivateSignal(Output4)
M18 code:
There is a liquid running from the .5 axis and as a result of the delay I get a big dot in the beginning and in the end of the contour.
Do I need a faster PC?
Because I had to modify the hardware and the postproseccor I did not try the "Z is 2.5D on Output #6" on config->state... window. Do you thing that it will make any difference?
What else do you recommend?
Thank you
Re: Fast Z on 2.5D machine
« Reply #1 on: November 06, 2006, 07:24:15 AM »
Hey Axil,
    I don't know if this will have any bearing but, what is your debounce set at?
« Reply #2 on: November 06, 2006, 08:23:43 AM »
I think this is an input parameter...
I have both "debounce interval" and "index debounce" set to 0 (zero).
« Reply #3 on: November 06, 2006, 08:40:51 AM »
What is this output controlling?
« Reply #4 on: November 06, 2006, 08:43:03 AM »
a valve
« Reply #5 on: November 06, 2006, 08:59:48 AM »
What speed is your PC, Version of Mach? operating system. I'm pulling at straws to be honest. I'm mainly trying to get info. for the experts. ;D I will help all I can though.
The other Sid
« Reply #6 on: November 06, 2006, 09:40:50 AM »
What Version of Mach are you using?
« Reply #7 on: November 06, 2006, 01:18:38 PM »
CPU speed: 1400Mhz
Mach version: 1.90.027
OS: win2k
« Reply #8 on: November 06, 2006, 02:48:35 PM »
That's kind of an older version, I would upgrade to the 2.0 ver for starters.
« Reply #9 on: November 06, 2006, 05:29:38 PM »
Take out the Mcodes :) they are WAY to slow for what you are looking to do :(
Try using E1 P1 for external activation 1 ON
and E1 P0 to turn it off
I think that is how it works... there is an example on the forum some place... The E1P1 needs to be on it own line btw
Brian
www.newfangledsolutions.com
www.machsupport.com
