Hello Guest it is October 21, 2026, 06:11:53 AM
Author Topic: G92 Offest Problem (maybe)  (Read 19603 times)
« on: November 25, 2010, 11:24:51 PM »
I've been using Mach-3 for a long time, and I just now started using G92 in a recent program but it seems to be offsetting in the opposite direction. For example, if I use "G92 X3.0" the offset becomes negative (X-3.0). I confirmed this in the diagnostic tab which shows the actual G92 counters for each axis. If I use "G92 X-3.0" then the X axis gets offest by a positive 3.0!  What's going on here? Am I misinterpreting how G92 is supposed to work, or is there a bug in the program?  ???
Thanks!
Some people are like a Slinky -- not much good for anything, but it brings a smile to your face when you shove it down a flight of stairs.
Re: G92 Offest Problem (maybe)
« Reply #1 on: November 26, 2010, 02:13:13 AM »
I think it may be right if I am understanding what you are saying. Here is snippet of what the G-Code button says
Here is an example. Suppose the current point is at X=4 in the currently specified coordinate system and the current X-axis offset is zero, then G92 X7 sets the X-axis offset to -3, sets parameter 5211 to -3, and causes the X-coordinate of the current point to be 7.
« Reply #2 on: November 26, 2010, 11:37:15 AM »
Hood -- Thanks for your reply.  Even though I have read the description of how G92 is supposed to work, I was not able to understand it until I "played" with it under a number of different situations. Now I understand it, and it makes sense.
This is what confused me before. As an example, my current physical X position is at X0.0. I want to offest the current zero position 3 inches (approx 76mm) in the plus direction so that I can call a subroutine to repeat a pattern in the offest position. Originally, I inserted "G92 X3.0" into my Gcode, but when the program executed a "G0 X0.0" the X-axis moved 3 inches in the minus direction, which was opposite to what I expected. But now I realize that the G92 offset made my X position shifted to X3.0, and when I executed the "G0 X0.0" it made the X-axis move in the minus direction. That's what confused me, but now I understand it.
Thanks again,
xray_man
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: November 26, 2010, 11:42:02 AM »
Use G52 instead it is a local shift and will offset as you expect, G92 is to be used instead of G54
Graham
« Reply #4 on: November 26, 2010, 11:49:13 AM »
Graham
Hi Graham -- Yes, I will use G52 from now on because it makes more sense for what I need it to do. Thanks very much!
xray_man
  •  2,785 2,785
« Reply #5 on: November 26, 2010, 11:52:30 AM »
Don't forget to cancel with G52 X0 at the end of the code section. There are lots of examples on here of how to use the command.
Graham
« Reply #6 on: November 28, 2010, 11:16:35 AM »
Graham
Okay, thanks again Graham!  ;D
