Hello Guest it is October 22, 2026, 04:17:51 PM
Author Topic: On screen keyboard help?  (Read 12920 times)
« on: November 05, 2006, 09:42:50 PM »
My intensions are to make a new MDI screen with large keyboard buttons for use with my touch screen LCD monitor.
I do not intend on having a keyboard or mouse by my mill, only a screen and somewhere to hang my pendant.
I have been reading the threads for keyboards and touch screens, it seems there is a solution with that on screen keyboard, however I would be much happier if I could design my own keyboard in mach3 directly.
Is this possible yet or is someone working on something?
I have tried to add buttions in screen4, but when used in mach to enter a single line of code into the MDI line, pressing that button exits the MDI line.
Cheers,
James.
Re: On screen keyboard help?
« Reply #1 on: November 06, 2006, 07:14:41 AM »
Have you read, watched the screen designer tips and tutors.? These should help. Wish I could tell you more. I'd have to research myself.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #2 on: November 06, 2006, 11:35:01 AM »
James,
If you have or can use a SWF compiler program, I'll have the code done for the MDI for Flash screens in Mach within the next few days.
If you don't have a SWD compiler program we'll have a number of screens to chose from,actually the setup you want will be one of the first screens we'll have. I should have some time tonight to finish the code and construct a demo screen for you to test.
If you would rather not use Flash, Art is working on adding this to Mach in the future. Currently there is a calculator for DRO's in Mach and this will be adapted for the MDI as well.
If you want send me a sketch of what your thinking for your screen  ;D
« Last Edit: November 06, 2006, 11:37:50 AM by zealous »
« Reply #3 on: November 06, 2006, 01:37:41 PM »
thanks zealous,
I am still building the machine at present, maybe 4 more weeks before power goes on so no immediate rush, those Flash screens look the way to go in future. I know very little about programing and compilers, but am keen to learn more.
The touch screen should arrive next week, I just want to be prepaired.
Cheers,
James.
