Hello Guest it is November 22, 2026, 02:29:06 PM
Author Topic: DXF-Mach2-Scale  (Read 19780 times)
Re: DXF-Mach2-Scale
« Reply #10 on: November 26, 2010, 10:30:41 AM »
I don't know what is in Mach 2 and do not know anything about SW. I will  assume that it saves the drawing as ver 12 dxf.
Go to CONFIG>PORT & PINS>TURN OPTIONS and check the box Reversed Arcs in Front tool post.
That should solve the crop circle problem.
Re: DXF-Mach2-Scale
« Reply #11 on: November 26, 2010, 10:50:14 AM »
The big circles could be from a IJ setting most CAMS use incremental. Check your config file for the proper setting in mach.
