Hello Guest it is November 13, 2026, 05:11:48 PM
Author Topic: PoKeys 10.6.1 (minor bug fix), released......  (Read 10777 times)
« on: November 23, 2010, 08:49:26 AM »
update 10.6.1 23Nov10
1). Minor bug fix, in where if you where in step jog, with a large step amount set.
If you then jogged, and decided to let go of the "Enable" button on the OEM 4/6 axis
pendants that the machine would still move till the it reached the Step amount setting.
FIXED: Put a Stop all Axis Motion when the Enable button is NOT pushed.
Bug Report from: "Thomaz Khul".
The new installer was sent to Boris, as of today, you only need this one IF!! your running the "Stock"
4/6 axis, or (when the future PoPendant is released), Pendants. Otherwise this update doesnt effect you.
scott
Offline borisz
  •  220 220
    • www.poscope.com
Re: PoKeys 10.6.1 (minor bug fix), released......
« Reply #1 on: November 23, 2010, 09:53:08 AM »
It can be downloaded  here .
regards
Boris
« Last Edit: November 23, 2010, 09:57:45 AM by borisz »
