Hello Guest it is October 21, 2026, 02:53:36 PM
Author Topic: continuous motion and tangential cutting problem  (Read 34299 times)
« on: November 17, 2010, 11:30:44 AM »
hi
i use my cnc to cut with a knife with tangential motion on, and the feed rate is very fast compared to milling. what i notice is that the motion stops at each point, or code line, and then starts again, resulting in the machine shaking.
i wonder if anyone knows how to get continuous motion so that the axes move wit smooth flowing motion?
another problem i cannot solve is that for tangential knife cutting the knife will spin (A axis) in the material at what appears to be random times - it generally works fine, and only seems t do this once per cut-out shape.
many thanks.
Re: continuous motion and tangential cutting problem
« Reply #1 on: November 17, 2010, 12:32:19 PM »
Afraid I have never used Tanegential Control so not sure if CV will work or not with it but try putting a G64 at the start of your code and see if that helps.
  •  9,374 9,374
« Reply #2 on: November 18, 2010, 02:27:36 AM »
I don't use tangential control but I do use a rotary A Axis. There were some issues between different versions of Mach and the function of 'Rot 360 Rollover and Ang Short Rot on G0' (General config page). Have you set these functions correctly ?
I believe this was all sorted a while back so it my be worth checking that you are using the latest lockdown version.
« Reply #3 on: November 18, 2010, 04:46:30 AM »
thanks hood.  G64 doesn't appear to change anything though, still stopping on each move resulting in machine shaking a lot and moving very slowly where there are a lot of short moves such as going around a small rounded corner.  i have a vinyl cutter (plotter) for cutting vinyl lettering from film and i wonder why i cant get the same smooth flowing motion which you get on this machine.
« Reply #4 on: November 18, 2010, 04:48:38 AM »
thanks tweakie i haven't looked at that, all new to me so i will have to read up on it.
« Reply #5 on: November 18, 2010, 06:55:45 AM »
Can you attach the code you are running  please.
« Reply #6 on: November 18, 2010, 02:29:24 PM »
here is the g code generated by v carve (vectric) with arc fitting on, i had to cut it short though as it exceeded 2000 charcters which is the max i can send you. i couldn't see how to attach a file.  thanks for looking at this, much appreciated.
( 1-5mmtolfrommark )
( File created: Thursday, November 18, 2010 - 09:51 AM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 1617.624, Y= 1690.919, Z= 15.000)
(Toolpaths used in this file:)
(1-5mmtolfrommark)
(Tools used in this file: )
(1 = End Mill {0.25 inch})
N95 G64
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {0.25 inch})
N140G00G43Z20.000H1
N150S12000M03
N160(Toolpath:- 1-5mmtolfrommark)
N170()
N180G94
N190X0.000Y0.000F10000.0
N200G00X321.676Y145.407Z6.000
N210G1Z-15.000F10000.0
N220G2X309.638Y187.939I22.272J29.273
N230G3X310.924Y199.087I-20.832J8.051
N240G3X303.667Y216.825I-38.469J-5.385
N250G2X293.448Y250.903I42.111J31.199
N260G3X284.253Y254.087I-86.685J-235.451
N270G2X275.188Y257.625I25.843J79.585
N280G2X253.035Y273.139I31.405J68.417
N290G2X250.857Y282.258I6.436J6.357
N300G1X286.699Y364.056
N310G2X293.875Y369.244I9.498J-5.581
N320G2X302.549Y367.474I2.322J-10.766
N330G2X320.831Y352.990I-121.964J-172.717
N340G3X354.411Y325.628I346.319J390.735
N350G2X355.297Y342.423I68.682J4.797
N360G2X358.992Y351.509I23.056J-4.080
N370G2X383.563Y362.222I20.782J-14.132
N380G2X407.345Y356.764I-24.811J-162.671
N390G2X411.087Y363.571I8.063J0.000
N400G2X421.661Y365.852I8.379J-13.200
N410G2X426.783Y368.135I15.421J-27.702
N420G3X432.040Y370.089I-36.537J106.381
N430G2X423.302Y379.872I104.534J102.155
N440G2X415.576Y390.278I110.564J90.163
N450G2X424.424Y407.870I9.362J6.313
N460G3X448.179Y409.575I-20.764J455.737
N470G1X447.181Y412.515
N480G1X446.247Y415.408
N490G1X445.376Y418.255
N500G1X444.570Y421.055
N510G1X443.827Y423.807
N520G1X443.148Y426.512
N530G1X442.534Y429.168
N540G1X441.983Y431.777
N550G1X441.497Y434.336
N560G1X441.076Y436.846
N570G1X440.719Y439.307
N580G1X440.427Y441.717
N590G1X440.200Y444.078
N600G1X440.110Y445.239
N610G1X440.037Y446.388
N620G1X439.980Y447.523
N630G1X439.939Y448.646
N640G1X439.915Y449.756
N650G1X439.907Y450.854
N660G1X439.917Y452.107
N670G1X439.950Y453.350
N680G1X440.004Y454.578
N690G1X440.080Y455.785
N700G1X440.230Y457.596
N710G1X440.422Y459.387
N720G1X440.657Y461.160
N730G1X440.934Y462.914
N740G1X441.253Y464.650
N750G1X441.614Y466.368
N760G1X442.019Y468.068
N770G1X442.465Y469.751
N780G1X442.955Y471.416
N790G1X443.487Y473.063
N800G1X444.062Y474.693
N810G1X444.680Y476.306
N820G1X445.341Y477.902
N830G1X446.045Y479.481
N840G1X446.792Y481.044
N850G1X447.583Y482.591
N860G1X448.417Y484.121
N870G1X449.294Y485.635
N880G1X450.216Y487.133
N890G1X451.180Y488.616
N900G1X452.189Y490.083
N910G1X453.241Y491.535
N920G1X454.338Y492.971
N930G1X455.478Y494.393
N940G1X456.662Y495.800
N950G1X457.891Y497.191
N960G1X459.164Y498.569
N970G1X460.481Y499.932
N980G1X461.843Y501.281
N990G1X463.249Y502.616
N1000G1X464.700Y503.937
N1010G1X466.196Y505.245
N1020G1X467.502Y506.345
N1030G1X468.833Y507.432
N1040G1X470.190Y508.506
N1050G1X471.570Y509.567
N1060G1X472.975Y510.616
N1070G1X474.402Y511.654
N1080G1X475.851Y512.680
N1090G1X477.322Y513.696
N1100G1X478.815Y514.703
N1110G1X480.328Y515.700
N1120G1X481.860Y516.688
N1130G1X483.412Y517.668
N1140G1X484.983Y518.640
N1150G1X486.572Y519.605
N1160G1X489.801Y521.516
N1170G1X493.094Y523.405
N1180G1X496.448Y525.276
N1190G1X499.856Y527.133
N1200G1X503.314Y528.982
N1210G1X506.817Y530.826
N1220G1X510.360Y532.670
N1230G1X517.546Y536.374
N1240G1X528.079Y541.818
N1250G1X533.397Y544.614
N1260G1X538.743Y547.482
N1270G1X541.425Y548.948
N1280G1X544.110Y550.438
N1290G1X546.800Y551.955
N1300G1X549.493Y553.499
N1310G1X552.188Y555.073
N1320G1X554.885Y556.679
N1330G1X557.583Y558.319
N1340G1X560.282Y559.996
N1350G1X561.089Y560.515
N1360G1X561.883Y561.047
N1370G1X562.664Y561.591
N1380G1X563.431Y562.148
N1390G1X564.185Y562.718
N1400G1X564.926Y563.300
N1410G1X565.654Y563.894
N1420G1X566.370Y564.500
N1430G1X567.074Y565.118
N1440G1X567.766Y565.747
N1450G1X568.446Y566.388
N1460G1X569.115Y567.040
N1470G1X569.772Y567.703
N1480G1X570.419Y568.376
N1490G1X571.679Y569.755
N1500G1X572.898Y571.176
N1510G1X574.078Y572.636
N1520G1X575.220Y574.134
N1530G1X576.326Y575.670
N1540G1X577.397Y577.241
N1550G1X578.437Y578.845
N1560G1X579.446Y580.483
N1570G1X580.427Y582.152
N1580G1X581.381Y583.850
N1590G1X582.310Y585.577
N1600G1X583.216Y587.331
N1610G1X584.101Y589.110
N1620G1X584.967Y590.913
N1630G1X585.815Y592.739
N1640G1X586.647Y594.586
N1650G1X587.466Y596.452
N1660G1X588.272Y598.337
N1670G1X589.068Y600.239
N1680G1X590.638Y604.088
N1690G1X592.189Y607.987
N1700G1X593.736Y611.925
N1710G1X596.797Y619.677
N1720G1X598.371Y623.559
N1730G1X599.992Y627.436
N1740G1X600.824Y629.370
N1750G1X601.672Y631.299
N1760G1X602.540Y633.224
N1770G1X603.427Y635.142
N1780G1X604.336Y637.054
N1790G1X605.268Y638.958
N1800G1X606.226Y640.853
N1810G1X607.210Y642.738
N1820G1X608.223Y644.612
N1830G1X609.266Y646.476
N1840G1X610.341Y648.326
N1850G1X611.450Y650.163
N1860G1X612.593Y651.986
N1870G1X613.774Y653.794
N1880G1X614.993Y655.585
N1890G1X616.253Y657.360
N1900G1X617.554Y659.116
N1910G1X618.899Y660.853
N1920G1X620.289Y662.571
N1930G1X621.727Y664.268
N1940G1X623.213Y665.943
N1950G1X624.749Y667.596
N1960G1X626.337Y669.225
N1970G1X627.979Y670.829
N1980G1X628.935Y671.727
N1990G1X629.902Y672.611
N2000G1X630.883Y673.480
N2010G1X631.876Y674.335
N2020G1X632.883Y675.176
N2030G1X633.901Y676.003
N2040G1X634.933Y676.816
N2050G1X635.978Y677.614
N2060G1X637.035Y678.399
N2070G1X638.106Y679.169
N2080G1X639.190Y679.925
N2090G1X640.286Y680.668
N2100G1X641.396Y681.396
N2110G1X642.519Y682.110
N2120G1X643.655Y682.810
N2130G1X644.804Y683.496
N2140G1X645.966Y684.168
N2150G1X647.142Y684.826
N2160G1X648.331Y685.469
N2170G1X649.533Y686.099
N2180G1X650.749Y686.715
N2190G1X651.978Y687.317
N2200G1X653.221Y687.905
N2210G1X654.477Y688.479
N2220G1X655.746Y689.040
N2230G1X657.030Y689.586
N2240G1X658.326Y690.118
N2250G1X659.637Y690.637
N2260G1X660.961Y691.141
N2270G1X662.299Y691.632
N2280G1X663.651Y692.109
N2290G1X665.016Y692.572
N2300G1X666.395Y693.022
N2310G1X667.788Y693.457
N2320G1X669.195Y693.879
N2330G1X670.616Y694.287
N2340G1X672.051Y694.681
N2350G1X673.500Y695.061
N2360G1X674.963Y695.428
N2370G1X676.441Y695.780
N2380G1X677.932Y696.120
N2390G1X679.437Y696.445
N2400G1X680.957Y696.757
N2410G1X682.491Y697.055
N2420G1X684.039Y697.339
N2430G1X685.602Y697.610
N2440G1X687.179Y697.867
N2450G1X688.770Y698.111
N2460G1X690.376Y698.340
N2470G1X691.996Y698.557
N2480G1X693.631Y698.759
N2490G1X695.280Y698.948
N2500G1X698.623Y699.286
N2510G1X702.024Y699.569
N2520G1X705.484Y699.798
N2530G1X709.003Y699.973
N2540G1X712.582Y700.095
N2550G1X716.221Y700.162
N2560G1X717.514Y700.164
N2570G1X718.796Y700.142
N2580G1X720.067Y700.097
N2590G1X721.326Y700.028
N2600G1X722.538Y701.077
N2610G1X723.770Y702.165
N2620G1X726.294Y704.452
N2630G1X728.895Y706.884
N2640G1X731.569Y709.456
N2650G1X734.315Y712.162
N2660G1X737.129Y714.998
N2670G1X740.008Y717.958
N2680G1X742.950Y721.038
N2690G1X745.951Y724.232
N2700G1X749.010Y727.534
N2710G1X752.123Y730.941
N2720G1X755.287Y734.446
N2730G1X758.501Y738.045
N2740G1X761.759Y741.733
N2750G1X765.061Y745.504
N2760G1X768.404Y749.353
N2770G1X771.783Y753.275
N2780G1X775.197Y757.265
N2790G1X778.643Y761.318
N2800G1X782.119Y765.428
N2810G1X789.145Y773.802
N2820G1X796.254Y782.345
N2830G1X803.422Y791.016
N2840G1X810.629Y799.774
N2850G1X825.066Y817.388
N2860G1X836.927Y831.865
N2870G1X848.553Y845.994
N2880G1X854.256Y852.883
N2890G1X859.874Y859.631
N2900G1X865.398Y866.219
N2910G1X870.819Y872.630
N2920G1X876.130Y878.846
N2930G1X881.320Y884.848
N2940G1X886.382Y890.618
N2950G1X888.862Y893.410
N2960G1X891.307Y896.138
N2970G1X893.715Y898.798
N2980G1X896.086Y901.390
N2990G1X898.418Y903.910
N3000G1X900.710Y906.356
N3010G1X902.961Y908.726
N3020G1X905.170Y911.017
N3030G1X907.337Y913.228
N3040G1X909.459Y915.356
N3050G1X911.645Y917.508
N3060G1X913.830Y919.619
N3070G1X916.013Y921.688
N3080G1X918.196Y923.715
N3090G1X920.376Y925.701
N3100G1X922.555Y927.646
N3110G1X924.733Y929.548
N3120G1X926.908Y931.409
N3130G1X929.081Y933.228
N3140G1X931.252Y935.004
N3150G1X933.421Y936.739
N3160G1X935.588Y938.432
N3170G1X937.752Y940.082
N3180G1X939.913Y941.690
N3190G1X942.071Y943.255
N3200G1X944.227Y944.778
N3210G1X946.380Y946.259
N3220G1X948.530Y947.696
N3230G1X950.676Y949.091
N3240G1X952.819Y950.443
N3250G1X954.959Y951.753
N3260G1X957.095Y953.019
N3270G1X959.228Y954.242
N3280G1X961.356Y955.422
N3290G1X963.481Y956.559
N3300G1X965.602Y957.652
N3310G1X967.719Y958.702
N3320G1X969.831Y959.709
N3330G1X971.939Y960.672
N3340G1X974.042Y961.591
N3350G1X976.141Y962.467
N3360G1X978.235Y963.299
N3370G1X979.844Y963.908
N3380G1X981.413Y964.478
N3390G1X982.942Y965.008
N3400G1X984.429Y965.500
N3410G1X985.875Y965.956
N3420G1X987.279Y966.377
N3430G1X988.641Y966.764
N3440G1X989.959Y967.119
N3450G1X991.234Y967.443
N3460G1X992.465Y967.738
N3470G1X993.651Y968.004
N3480G1X994.793Y968.244
N3490G1X995.889Y968.458
N3500G1X996.939Y968.648
N3510G1X998.898Y968.961
N3520G1X1000.668Y969.195
N3530G1X1002.244Y969.361
N3540G1X1003.621Y969.468
N3550G1X1004.796Y969.529
N3560G1X1005.766Y969.555
N3570G1X1006.525Y969.556
N3580G1X1007.397Y969.527
N3590G1X1008.170Y969.450
N3600G1X1008.927Y969.315
N3610G1X1009.665Y969.125
N3620G1X1010.383Y968.882
N3630G1X1011.076Y968.587
N3640G1X1011.743Y968.242
N3650G1X1012.380Y967.850
N3660G1X1012.986Y967.412
N3670G1X1013.558Y966.930
N3680G1X1014.092Y966.407
N3690G1X1014.587Y965.844
N3700G1X1015.039Y965.242
N3710G1X1015.446Y964.606
N3720G1X1015.806Y963.935
N3730G1X1016.115Y963.232
N3740G1X1016.250Y962.869
N3750G1X1016.372Y962.499
N3760G1X1016.568Y961.765
N3770G1X1016.706Y961.026
N3780G1X1016.789Y960.285
N3790G1X1016.816Y959.546
N3800G1X1016.800Y958.979
N3810G1X1016.752Y958.416
N3820G1X1016.672Y957.857
N3830G1X1016.562Y957.306
N3840G1X1016.420Y956.762
N3850G1X1016.248Y956.227
N3860G1X1016.046Y955.703
N3870G1X1015.815Y955.190
N3880G1X1015.554Y954.690
N3890G1X1015.264Y954.205
N3900G1X1014.946Y953.735
N3910G1X1014.600Y953.282
N3920G1X1014.226Y952.848
N3930G1X1013.825Y952.433
N3940G1X1013.397Y952.039
N3950G1X1012.943Y951.667
N3960G1X1012.187Y951.043
N3970G1X1011.314Y950.273
N3980G1X1010.348Y949.366
N3990G1X1009.311Y948.335
N4000G1X1008.226Y947.189
N4010G1X1007.115Y945.940
N4020G1X1006.558Y945.279
N4030G1X1006.003Y944.597
N4040G1X1005.452Y943.893
N4050G1X1004.910Y943.171
N4060G1X1004.379Y942.430
N4070G1X1003.861Y941.673
N4080G1X1003.359Y940.901
N4090G1X1002.877Y940.114
N4100G1X1002.417Y939.315
N4110G1X1001.983Y938.504
N4120G1X1001.576Y937.683
N4130G1X1001.199Y936.854
N4140G1X1000.857Y936.017
N4150G1X1000.551Y935.174
N4160G1X1000.284Y934.327
N4170G1X1000.059Y933.476
N4180G1X999.879Y932.622
N4190G1X999.747Y931.768
N4200G1X999.666Y930.915
N4210G1X999.638Y930.064
N4220G1X999.646Y929.640
N4230G1X999.670Y929.220
N4240G1X999.709Y928.802
N4250G1X999.763Y928.388
N4260G1X999.915Y927.568
N4270G1X1000.124Y926.761
N4280G1X1000.388Y925.966
N4290G1X1000.704Y925.183
N4300G1X1001.070Y924.414
N4310G1X1001.483Y923.657
N4320G1X1001.942Y922.913
N4330G1X1002.444Y922.182
N4340G1X1002.986Y921.464
N4350G1X1003.567Y920.760
N4360G1X1004.184Y920.069
N4370G1X1004.834Y919.391
N4380G1X1005.516Y918.727
N4390G1X1006.227Y918.078
N4400G1X1006.965Y917.442
N4410G1X1007.727Y916.820
N4420G1X1008.512Y916.212
N4430G1X1009.316Y915.619
N4440G1X1010.138Y915.040
N4450G1X1010.975Y914.476
N4460G1X1011.824Y913.926
N4470G1X1012.685Y913.392
N4480G1X1013.553Y912.872
N4490G1X1014.428Y912.367
N4500G1X1016.185Y911.404
N4510G1X1017.939Y910.503
N4520G1X1019.670Y909.664
N4530G1X1021.668Y908.751
N4540G1X1023.747Y907.856
N4550G1X1025.907Y906.977
N4560G1X1028.148Y906.116
N4570G1X1030.469Y905.272
N4580G1X1032.871Y904.446
N4590G1X1035.352Y903.637
N4600G1X1037.914Y902.845
N4610G1X1040.555Y902.071
N4620G1X1043.276Y901.314
N4630G1X1046.076Y900.576
N4640G1X1048.956Y899.854
N4650G1X1051.914Y899.150
N4660G1X1054.951Y898.464
N4670G1X1058.068Y897.796
N4680G1X1061.262Y897.145
N4690G1X1064.535Y896.513
N4700G1X1067.886Y895.898
N4710G1X1071.315Y895.300
N4720G1X1074.822Y894.721
N4730G1X1078.407Y894.160
N4740G1X1082.069Y893.616
N4750G1X1085.808Y893.091
N4760G1X1089.625Y892.584
N4770G1X1093.518Y892.094
N4780G1X1097.488Y891.623
N4790G1X1101.535Y891.170
N4800G1X1105.658Y890.735
N4810G1X1109.857Y890.318
N4820G1X1114.132Y889.920
N4830G1X1118.484Y889.539
N4840G1X1122.911Y889.177
N4850G1X1127.250Y888.812
N4860G1X1131.575Y888.402
N4870G1X1135.886Y887.947
N4880G1X1140.183Y887.448
N4890G1X1144.465Y886.905
N4900G1X1148.732Y886.318
N4910G1X1152.984Y885.686
N4920G1X1157.222Y885.010
N4930G1X1161.443Y884.291
N4940G1X1165.649Y883.527
N4950G1X1169.839Y882.720
N4960G1X1174.012Y881.868
N4970G1X1178.170Y880.973
N4980G1X1182.310Y880.034
N4990G1X1186.434Y879.051
N5000G1X1190.541Y878.025
N5010G1X1194.630Y876.955
N5020G1X1198.703Y875.841
N5030G1X1202.757Y874.684
N5040G1X1206.793Y873.484
N5050G1X1210.811Y872.240
N5060G1X1214.811Y870.953
N5070G1X1218.792Y869.622
N5080G1X1222.755Y868.249
N5090G1X1226.698Y866.832
N5100G1X1230.622Y865.372
N5110G1X1234.526Y863.869
N5120G1X1238.411Y862.324
N5130G1X1242.276Y860.735
N5140G1X1246.120Y859.104
N5150G1X1249.945Y857.429
N5160G1X1253.748Y855.712
N5170G1X1256.778Y854.307
N5180G1X1259.794Y852.875
N5190G1X1262.797Y851.416
N5200G1X1265.787Y849.929
N5210G1X1268.763Y848.416
N5220G1X1271.726Y846.876
N5230G1X1274.674Y845.309
N5240G1X1277.609Y843.715
N5250G1X1280.529Y842.095
N5260G1X1283.435Y840.449
N5270G1X1286.326Y838.776
N5280G1X1289.203Y837.077
N5290G1X1292.065Y835.351
N5300G1X1294.912Y833.600
N5310G1X1297.744Y831.823
N5320G1X1300.560Y830.019
N5330G1X1303.361Y828.191
N5340G1X1306.147Y826.336
N5350G1X1308.916Y824.456
N5360G1X1311.670Y822.550
N5370G1X1314.408Y820.619
N5380G1X1317.130Y818.663
N5390G1X1319.835Y816.682
N5400G1X1322.523Y814.675
N5410G1X1325.195Y812.644
N5420G1X1327.851Y810.588
N5430G1X1330.489Y808.507
N5440G1X1333.110Y806.401
N5450G1X1335.714Y804.271
N5460G1X1338.300Y802.117
N5470G1X1340.869Y799.938
N5480G1X1343.420Y797.734
N5490G1X1346.903Y794.661
N5500G1X1350.290Y791.601
N5510G1X1353.580Y788.556
N5520G1X1356.774Y785.529
N5530G1X1359.872Y782.525
N5540G1X1362.876Y779.547
N5550G1X1365.785Y776.597
N5560G1X1368.599Y773.680
N5570G1X1371.321Y770.799
N5580G1X1373.949Y767.957
N5590G1X1376.484Y765.157
N5600G1X1378.927Y762.404
N5610G1X1381.279Y759.699
N5620G1X1383.539Y757.048
N5630G1X1385.708Y754.452
N5640G1X1387.787Y751.916
N5650G1X1389.776Y749.443
N5660G1X1391.676Y747.036
N5670G1X1393.487Y744.699
N5680G1X1395.209Y742.435
N5690G1X1396.843Y740.247
N5700G1X1398.390Y738.139
N5710G1X1399.850Y736.114
N5720G1X1401.223Y734.175
N5730G1X1402.510Y732.327
N5740G1X1403.711Y730.572
N5750G1X1404.827Y728.913
N5760G1X1405.859Y727.355
N5770G1X1407.669Y724.552
N5780G1X1409.146Y722.189
N5790G1X1410.569Y719.833
N5800G1X1411.446Y718.319
« Reply #7 on: November 18, 2010, 03:30:54 PM »
What is the lookahead set to on General config page? maybe that is fairly small and you will need to increase as there are lots of small segments there.
As for the part where the knife rotates, is that near the start i9n the G2/G3 moves, if so I think that may be the problem as I am sure tangential control only works with G1's
« Reply #8 on: November 23, 2010, 05:43:25 AM »
hi hood
the lookahead is 20.
yes i have noticed that when the knife spins around it is only with arc moves, not G1s.
« Reply #9 on: November 23, 2010, 06:23:59 AM »
hi Tweakie
both Rot 360 Rollover and Ang Short Rot on G0 are not ticked - is this correct?
version of mach i am using is R2.2 so not the latest.  i cant see any info about upgrading versions, is it straight forward ie. run the new version and it overwrites the old?
thanks for your help.
