Hello
Guest
it is
November 24, 2026, 06:10:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Z axis drift during X-axis motion...
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Z axis drift during X-axis motion... (Read 47971 times)
Chet
58
on:
November 14, 2010, 03:08:28 PM »
I'm using Mach3 with a computer running Windows XP and a HobbyCNC driver board.
I've noticed that the Z-axis motor will rotate slightly during runs on the X-axis only.
It is stable on Y-axis runs.
I'd love to get rid of the drift...
And, yes, I've already added the extra capacitors to the cables going into the HobbyCNC board to ground out cross-talk.
So I'm open to new suggestions...
Chet
Logged
Carnoustie, Scotland
Re: Z axis drift during X-axis motion...
Reply #1 on:
November 14, 2010, 03:17:09 PM »
Either electrical noise, possibly even on the output side of the drives or you have duplicated pins in Mach.
If you attach your xml I can check your config.
Logged
Chet
58
Reply #2 on:
November 14, 2010, 04:07:33 PM »
Okay, which of the reply icons would I use to attach that file???
On regular e-mail I'd be confident, but I'm not seeing what I'm looking for in the icon list.
Of course it could be there, I just don't recognize it...
Chet
Logged
Reply #3 on:
November 14, 2010, 04:17:25 PM »
On the reply page you will see the additional options button, you can use that to attach your xml. You may need to rename it first though if it has a standard name as the forum only accepts a file name once.
Logged
Chet
58
Reply #4 on:
November 14, 2010, 05:55:39 PM »
Okay, let's see if I'm uploading the file correctly...
Hope you find something useful...
Chet
Logged
Reply #5 on:
November 15, 2010, 01:18:41 AM »
Dont see any problems of pin duplication in your config so it is likely that it is noise getting into the wiring.
Logged
Chet
58
Reply #6 on:
November 15, 2010, 08:16:38 AM »
Just performed an interesting test...
There is NO drifting of the Z-axis when I manually move the carriage along the X-axis with the keyboard commands.
It only occurs when the X-axis is moving during a program execution.
What does that imply?
Logged
Reply #7 on:
November 15, 2010, 09:12:59 AM »
Seems strange unless your code is calling a Z axis move. What if you MDI a X axis move?
Logged
Chet
58
Reply #8 on:
November 15, 2010, 09:22:59 AM »
MDI????
If this refers to moving the X-axis from the keyboard, I can do that
without
Z-axis drift.
Logged
Reply #9 on:
November 15, 2010, 09:29:33 AM »
MDI is manual Data Input
When you said you were moving via keyboard I presumed you were meaning jogging but you are meaning via entering G Code commands in MDI line?
If you are then I cant see how that would be any different than from Mach running code from a file.
When you start Mach and hit the Reset button for the first time do you get any messages?
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
