Hello Guest it is October 24, 2026, 03:47:10 PM
Author Topic: problem with parallel port  (Read 9850 times)
« on: November 12, 2010, 01:00:28 PM »
got a new computer wich has no integrated parallel port on it so I instaled paralell port card to connect computer to driver but.. mach3 has no control over card. the adress the it shows in properties is EC00. can u tell me what is the problem?
Re: problem with parallel port
« Reply #1 on: November 12, 2010, 01:49:59 PM »
Do the readouts in Mach  show movement when you jog?
« Reply #2 on: November 12, 2010, 03:12:45 PM »
Hi there!
I'm having the same problem. Mach3 seems to work correctly but the driver does not receive any signal from the parallel port. The parallel port acts as if the address is not the right one.
I've tried different addresses from the parallel port's properties but nothing happens. Is there any way to discover the correct address of the port other than resourses tab in properties?
