Hello Guest it is November 10, 2026, 01:53:05 AM
Author Topic: Wait until external application ends...  (Read 6985 times)
« on: November 12, 2010, 03:51:54 AM »
I'm using a button to call an external application:
Shell ("c:\myapplication.exe")
Inside the same button i want to load a file after "myapplication" file is closed.
LoadFile("c:\myfile.txt")
So, i need something like "~wait for myapplication to close" between these commands:
"Wait for myapplication to close"
How can i do that?
Re: Wait until external application ends...
« Reply #1 on: November 20, 2010, 11:15:15 AM »
The problem was solved as following:
I created a button which has VB script:
While IsLoading()
Sleep 100
Wend
This button has enabled a HOTKEY (for example key "0").
So when my application finishes, focuses on Mach application
and sends a keystroke "0" (the HotKey).
2-3 days of searching and i didn't find any other solution.
Still if you have any idea of controlling it through Mach,
please share.
Giannis
