Hello Guest it is October 13, 2026, 04:07:02 PM
Author Topic: spindle speed via modbus  (Read 12044 times)
« on: November 09, 2010, 06:46:39 AM »
Is it possible to control the spindle speed using a frequency inverter and sending the speed information from Mach3 via Modbus?
I know I can use PWM or pulse/dir signals, although I´m running out of available pins, so I thought using modbus for this.
Re: spindle speed via modbus
« Reply #1 on: November 09, 2010, 06:55:11 AM »
Yes, if your inverter can communicate via Modbus.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: November 09, 2010, 07:07:37 AM »
Yes, the inverter uses modbus and I know how to set it up for this.
I don´t know how to setup Mach3 to give this information tho the inverter via modbus.
« Reply #3 on: November 09, 2010, 07:20:04 AM »
Have a look at this thread. It shows how it was done for a Hitachi VFD.
http://www.machsupport.com/forum/index.php/topic,16316.0.html
You will need to look at your manual to find the appropriate registe numbers.
Cheers,
Peter.
Homann Designs
« Reply #4 on: November 10, 2010, 10:14:48 AM »
Peter,
Thanks a lot!!
I´ll take a deep look at that. It seems to be what I need.
