Hello Guest it is November 11, 2026, 08:10:39 PM
Author Topic: Modbus DRO  (Read 21833 times)
Modbus DRO
« on: November 08, 2010, 07:02:21 PM »
I´m working in a resin dispensing machine that uses Mach3 and has  a PLC to control some machine functions.
One functions the PLC controls is a variable speed resin pump. I need to control the pump speed from within a Mach3 screen.
The idea is to have a DRO in the screen with the pump RPM and be able to send this value to the PLC via modbus. The RPM value should be a discrete value going from 1 to 100.
I understand how to use modbus for bit signals (like a sensor on-off status) but I don´t get how to use it for discrete values.
Any leads to point me in the right direction would be greately appreciated.
Thanks.
Re: Modbus DRO
« Reply #1 on: November 24, 2010, 07:25:31 PM »
since your using output values, use OUTPUT HOLDING on the serial plugin modbus set up (note it will be a integer).
then in brian, map your DRO99 through a formula A*100 then to you serial plugin modbus config, local var as your termination.
scott
