Hello Guest it is November 10, 2026, 03:26:04 AM
Author Topic: Load G-code program externally  (Read 9337 times)
« on: November 04, 2010, 09:54:50 PM »
Hi All...
Is there a way to load a g-code program from another program.  I have an app written in VB.net that writes g-code to a file.  I'd like to have that file load automatically into mach after it is generated.  Is there a way to do this without using the Mach API?
  •  9,376 9,376
Re: Load G-code program externally
« Reply #1 on: November 05, 2010, 02:13:22 AM »
I don't know how to do it but obviously there is a way because LazyCam does just that.
« Reply #2 on: November 05, 2010, 07:37:39 AM »
I'd guess that LazyCam, being a mach plug-in, uses the mach SDK.  I can't use the SDK.  I don't have the right version of visual Studio.  I've tried the VS2008 plug-in a number of times but can't get anything beyond the sample apps that it creates automatically to run.  I'm wondering is using a COM connection to Mach would work and if so, how to go about doing it.
