Hello Guest it is October 05, 2026, 01:37:53 AM
Author Topic: Homing without switches  (Read 10514 times)
« on: October 31, 2010, 09:08:45 AM »
My old Dynapth control used marks and the encoder index pulse for homing on the X & Y axes, no homing switches.  I would like to use a similar approach with Mach/Galil.  I would like to zero at the mark, have the axis go .1" or so negative, reverse positive to the encoder index.  I tried simulating the home input with a brain (activating at -.100).  It shows to be working on the diagnostic screen, but will not reverse the axis when referencing like it should.  I suspect that the homing process is internal to the Galil, so it doesn't care what Mach sees, but I would like to know if there is a way around this.
Mike
Offline smurph
  •  1,575 1,575
Re: Homing without switches
« Reply #1 on: October 31, 2010, 11:16:21 PM »
No way around this.  Homing is integral to the Galil.  You could probably write your own homing routine in a separate thread in the Galil.  But that would be waaaaaaaaay more work than installing switches.
