Hello Guest it is September 11, 2026, 05:53:30 AM
Author Topic: Program to compare profiles and check ports / pins setting  (Read 12350 times)
« on: October 29, 2010, 05:54:59 AM »
I wrote a new program called MachProfile. That program can compare profile files and shows the differences. It also checks the port / pins settings.
It can be downloaded from http://www.kd-dietz.de.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Program to compare profiles and check ports / pins setting
« Reply #1 on: October 29, 2010, 06:14:14 AM »
That is going to be a very handy programme I think, excellent , thanks for sharing.
« Reply #2 on: October 29, 2010, 07:31:45 AM »
nice addition to your fine work
only issue for me was the button "Abbrechen" .... I assume it is "Cancel"
Thanks, I like it, very functional !!!
« Reply #3 on: October 30, 2010, 08:10:43 AM »
Hi Ya-Nvr-No
could you please give me the dialog-names where you find "abbrechen"?. Those are system-defined buttons, they should be set by the system to the language.
Klaus
« Reply #4 on: October 30, 2010, 09:17:58 AM »
It was on the:
Set filter page
Settings ---> Language ---> Dialog page
Actions ---> Check Ports and pins  page
« Last Edit: October 30, 2010, 09:22:38 AM by Ya-Nvr-No »
« Reply #5 on: October 30, 2010, 10:16:41 AM »
Hi Ya-Nvr-No
thank you for your answers. I fixed this issue. Version V1.00.a is ready for download.
Klaus
« Reply #6 on: May 26, 2011, 02:14:24 PM »
Hello,
I've released MachProfile V2.08 with the following changes and fixes.
Motor / axis page shows now the asigned ports and pins and most of the tuning parameters which can also be printed. "Save" and "Restore" saves and restores the following files: License, Profiles,  Fixtures and the following complete dirs: Addons, Flash, GCode, Plugins, SubRoutins, TurnAddons. Velocity value wasn't shown correct, fixed.
Klaus
