Hello Guest it is October 21, 2026, 08:52:42 PM
Author Topic: Was hosed until I found a magic "Minimum processor state" setting!  (Read 9894 times)
Offline Tj256
  •  45 45
Maybe I missed some instructions somewhere, but my machine has been acting erratic and generally not working. A big clue was my PWM frequency not being correct. Turns out there's a setting in Vista under control panel, power management, advanced power settings. Expand the tree and find "Minimum processor state". Make sure this is set to 100%. Also do the same for maximum.
Once I did this, my PWM frequency is correct and things work better than ever!
Offline Tj256
  •  45 45
Re: Was hosed until I found a magic "Minimum processor state" setting!
« Reply #1 on: October 25, 2010, 08:34:01 PM »
Mach should probably do some kind of loopback test or check for these settings in the registry. This would have saved me weeks of pain. Hopefully this tip can help someone else.
« Reply #2 on: November 13, 2010, 09:25:06 PM »
Were you then able to use a USB - parallel adapter?
Anyone know if Mach 4 will work with USB? Or we stuck with a parallel port?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: November 17, 2010, 09:14:19 AM »
You can't use a USB to parallel adapter, it will not work (they are only for printers.) There are a few different choices if you want to go USB. My favorite is the SmoothStepper: http://www.soigeneris.com/SmoothStepper-details.aspx (my website), there is also the DSPMC, and KFlop boards.
Happy machining , Jeff Birt
